Corner lights, Tail lights, and Signal lights don't work properly. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2011, 02:14 AM   #1 (permalink)
View TheHypeIsOver's Photo Gallery
4th Generation Corner lights, Tail lights, and Signal lights don't work properly.
Hello TN!
Well today I got my order of black housings and clear corner lights from Ebay for a 2000 Toyota Camry (Gen 4.5... I believe?) Well when I installed them I noticed everything works the Angel eyes and headlights but the only problem was that my taillights won't turn on unless I step on the brakes. Also for my corner lights I got some LED's and switched out the amber bulbs. They worked fine and I got the cool hypersignal thingy. I noticed that the LED's won't stay on like they usually would like with the amber bulbs. I drove the whole day without the back lights and corner lights working. Then I stopped by a friends house to try and fiddle around with the corner lights where I installed the LED's to see if I put back in the amber bulbs it would finally make the taillights work. I tried pulling it out and I broke one of the LED's (The plastic LED part snapped out of the metal bottom piece). Then I worked on the other side and I pulled it out but when I pulled it out a piece of the copper from the socket of the place where you plug in the LED/Bulb popped out. I then finally got to put the copper piece back in but I had to do some bending of the inside to get it in. So then I noticed my signal lights didn't work after. Neither the left or right worked. I then pressed the emergency signal lights and it clicked ONCE then turned off completely. I then couldn't get it to work anymore.
Complete fail... How can I try to fix this? Please and thank you.
TheHypeIsOver is offline   Reply With Quote
Old 06-18-2011, 02:23 AM   #2 (permalink)
2002,5SFE
View houra's Photo Gallery
I think, when you change to LED, you must change turn signal flasher relay or add resistor
houra is offline   Reply With Quote
Old 06-18-2011, 02:25 AM   #3 (permalink)
Do you believe this may have lead to the tail lights not working? Like it shorted or something? I actually like the hyper signal thing how it blinks fast. Now that my signal lights don't work that's not cool ):
Old 06-18-2011, 02:35 AM   #4 (permalink)
2002,5SFE
Check this, i hope it helps you:
Master List of LEDs Bulb Sizes & DIY/Tutorials for Interior/Exterior Lights
Old 06-18-2011, 05:38 AM   #5 (permalink)
Thanks for the effort but nothing helped me with my problem.
Old 06-18-2011, 06:00 AM   #6 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
I wonder when u were addin pieces of copper if u shorted a wire and it popped a fuse ?
Old 06-18-2011, 06:03 AM   #7 (permalink)
Perhaps, because that piece of copper was inside the socket where you plug the bulb/led in where the corner light piece is. When I yanked it out the copper piece flew right off and I tried stuffing it in. Didn't work so I had to bend the copper inside a little bit to squeeze the piece that popped out back in.
Old 06-18-2011, 07:31 AM   #8 (permalink)
IDE pull the coin tray out and inspect the Fuses. I bet ones blown.
The Following User Says Thank You to Mister_Perkins For This Useful Post:
TheHypeIsOver (06-19-2011)
