Serpintene pulleys - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2011, 07:08 PM   #1 (permalink)
View Bert97's Photo Gallery
Serpintene pulleys
I had a timing belt replaced last week and started hearing a whining noise when the air was cut on. While looking for the source of the noise I noticed that the 3 pulleys weren't alingned. The bottom pulley on the crank is sticking out 1/2" further than the other 2 pulleys. Shouldn't all 3 be aligned?
Bert97 is offline   Reply With Quote
Old 06-19-2011, 07:15 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Yep. Sounds like the crank bolt is loose
Old 06-21-2011, 06:56 PM   #3 (permalink)
Found the problem, the pulley looks like it's 2 pieces pressed together. The pulley indeed moved but the crank bolt was tight. I took a plastic hammer and tapped the pulley back in place, put the belt back on and everything sounded good. I'll order a new pulley and do the repair correctly.
Thanks,
Bert
Old 06-21-2011, 07:29 PM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
It could be old age that caused the rubber to disintegrate, or the mechanic could have used a jaw type puller to remove the pulley:
http://img.photobucket.com/albums/v4...Picture355.jpg
The above photo from a timing belt DIY (http://www.toyotanation.com/forum/t109966.html) showed what NOT to use when removing the crank pulley. I'd be interested in jaw marks on the pulley. Now you may or may not need a puller, but you can borrow one (OEM27019) from Autozone's free loaner program that's like the one HF sells:
http://www.harborfreight.com/46-piec...set-37824.html
Thanks,
Bert
