Cartopping a sailboat on a 95 Wagon - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-20-2011, 11:26 AM   #1 (permalink)
View noname87's Photo Gallery
Has anyone tried cartopping a boat on top of a 95 Camry Wagon?
I want to transport a 15 foot sailboat that weighs 200 lbs and a 40 lb mast on top of a 95 Camry wagon. I have a dealer installed rack that has a 100 lb limit on the cross bars. No idea if it is per bar or total. I was thinking I could use a set of Thule load bars or 2X4s attached to the factory rack with rope. This would be a one time affair of 350 miles.
Any ideas of this would work?
noname87 is offline   Reply With Quote
Old 06-20-2011, 12:17 PM   #2 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Lay down on roof. If you don't fall you should make it
I think its doable, dunno about the 15ft though.
carsrus is offline   Reply With Quote
Old 06-20-2011, 11:38 PM   #3 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
I would double check with the thule load bar settings....but I probably wouldn't do it....a 15ft boat, regardless of weight will catch a decent bit of wind as well. there's a pretty good chance that the weight could weaken the roof rack anchors and then the wind will take it off....
if you had an actual thule rack though, I'd say that you'd be good
HaHa
Old 06-21-2011, 11:08 AM   #4 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
i would only attempt that with a yakima or thule rack.
Old 06-21-2011, 11:09 AM   #5 (permalink)
Safari Wagon's Avatar
Gameroom cash: $213650
View Safari Wagon's Photo Gallery
What a task! And I thought I was the only crazy wagon boat hauler....
What is the beam on the boat? It may be so wide that when you put it on top of the car it will cover it like a hat....
Here is the most I've gotten out of my rack -
That is a Yakima Load Warror with extension on factory bars. I estimate the total weight to be about 140 pounds (2 12 foot kayaks - 45lbs each + cargo box with kayak saddles ~ 50lbs). This is exceeding the OEM luggage rack rating by 40 pounds.
What you have to be careful with when looking at aftermarket racks, is a problem with a short distance between the cross bars. The OEM rack allows you to spread the bars almost over the lenght of the roof. When you get a Thule/Yakima one, you will mount your towers in the door jambs which limits the spread. You may get a greater weight rating (maybe 150 versus the 100 oem) but you will not be able to spread your bars enough to support the load.
To avoid this, I would look at the aftermarket options that mount to your existing bars. I would also get a bunch of foam blocks to further spread the weight throughout the roof. Your idea of the 2x4s may be a good one too. The goal would be to spread the weight out as much as possible. I don't even want to start with the securing of the boat.
With that said, I would not do it unless I could stay under 30 mph.... And I don't say things like that a often....
Safari Wagon is offline   Reply With Quote
