Unknown Sensor plug missing. Need help identifying - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-20-2011, 08:30 PM   #1 (permalink)
View hardibity's Photo Gallery
I've been looking for quite some time to figure out what this sensor belongs to in my 1996 Camry LE. I thought it was my MAP sensor, but I always thought the map sensor had a 3 plug harness. Anyone know what this is?
hardibity is offline   Reply With Quote
Old 06-20-2011, 08:34 PM   #2 (permalink)
http://www.toyotanation.com/photos/s.../ppuser/130861
For some reason the photo didn't load but you can follow the link above. I also forgot to mention, the plug in questions has two prongs.
The plug in need looks like the one below, but only with 2 pins
Where can I find MAP Sensor Pigtail for Gen 3 Camry
Old 06-20-2011, 08:35 PM   #3 (permalink)
Old 06-20-2011, 10:50 PM   #4 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Could you pull back a bit to let us see a bit more of the engine compartment? That dingus sort of looks to be hanging off of the resonator, but that doesn't make a lot of sense. Is your CEL on? If so, have you pulled the codes?
Old 06-20-2011, 10:57 PM   #5 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
VSV for emissions? Idle Up valve?
Can't remember, I think its one of those two.
RichieRichJP is offline   Reply With Quote
Old 06-27-2011, 11:24 PM   #6 (permalink)
Thanks for the replies. I've linked 3 more pictures. I did have the codes pulled a while back and want to say it was was the MAP/Barometric Pressure Problem (p0106), The CEL is on, and i belieive it's from the missing wire.
Zoomed out:
Side View:
Top View:
Old 06-27-2011, 11:28 PM   #7 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
That is a VSV, dig around and see if you can find the harness for it.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 06-28-2011, 02:47 PM   #8 (permalink)
That's the problem, the pigtail was broken off and all I have is the wires. Where could I pick up a pigtail for the VSV valvue?
Old 06-28-2011, 03:29 PM   #9 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
cut it off at the salvage yard and splice it together using solder and shrink wrap
Old 06-28-2011, 03:46 PM   #10 (permalink)
Unfortunately there aren't many salvage yards near us. I wish there were though.
Old 06-28-2011, 03:52 PM   #11 (permalink)
30YRTOYOTAPARTSEXPERINCE
TOYOPARTSMAN's Avatar
Gameroom cash: $324600
iTrader Score: 12 reviews
View TOYOPARTSMAN's Photo Gallery
Do you have any of the old plug left?
Gary Smith-Parts Manager
garys@toyotaofnewnan.com
www.ToyotaofNewnan.com
678-854-9601
TOYOPARTSMAN is offline   Reply With Quote
Old 06-28-2011, 03:57 PM   #12 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
that's the VSV for EVAP plug you are missing.
Old 06-28-2011, 04:12 PM   #13 (permalink)
unfortunately, i dont have it. I think it fell off as I was driving.
Old 06-28-2011, 04:19 PM   #14 (permalink)
The pigtail that was sliced off should look like this, but with 2 ports not 3
Old 06-28-2011, 04:30 PM   #15 (permalink)
hill8570's Avatar
No salvage yards? Oh, the horror....
a) sweet talk someone on TN into wandering over to a pick-a-part and score one for you
b) find someone on fleabay selling a junkyard pull of the VSV, email them, and see if they'll sell you a connector (probably half the time, the connector is already on the junkyard pull, since it's easier to just snip the cable than disconnect the connector...not something you can count on, 'tho).
