Even as simple as this DIY may be, I see a few topics about this with little to no help
Tools necessary:
Flat head screwdriver
Philips screwdriver
#74 bulb
Where the area is circled red, you may notice a little area where your flathead can fit in nicely. Using the flathead, insert it and just pry out. You will need to use a little bit of force. The molding should just pop out and then you can place it elsewhere.
You may bend a metal clip while prying out like me. Here is where the two clips are on the molding.
After that, remove the screw circled in red
After that, the clear piece just comes right out. You will see the green covered bulb (circled red). Twist to your
right to detach the bulb housing from the clear piece.
After that you can replace it with a #74 bulb.
If you happen to break or bend the metal clip like me, the part # is 90468-04177.
Part # for factory bulb: 90981-11014
Part # for green bulb cap: 84998-10070
