Fuel filter removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-22-2011, 05:18 AM   #1 (permalink)
View jmc55ma's Photo Gallery
Fuel filter removal
Ok guys, I need your help again. I am trying to remove my fuel filter on my 2001 Camry 2.2L and the fuel inlet connection is rusty. I sprayed with WD40 and let sit overnight and it still will not budge. I removed the air cleaner and hoses for access and I have plenty of room to work but I am afraid to apply too much pressure to the line wrenches because of fear of breaking the fuel line. Any suggestions? btw...this is the original filter with 173000 miles on the odometer...HELP!!!!!
jmc55ma is offline   Reply With Quote
Old 06-22-2011, 06:55 AM   #2 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
first off, dont use wd40 - get some PB blaster. much better penetrating oil. im assuming you are using two wrenches to break the fitting loose, one on the filter nut and the other on the line nut. are you using flair nut wrenches? these work better than standard wrenches. then give it a solid and steady pull to loosen, but do keep an eye on the tubing to make sure it doesnt twist with the nut.
Old 06-22-2011, 07:03 AM   #3 (permalink)
2002,5SFE
View houra's Photo Gallery
houra is offline   Reply With Quote
Old 06-22-2011, 08:04 AM   #4 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
i don't like the tools being used on that youtube video, i prefer to use a good quality flare 14mm wrench for fuel nut to avoid rounding the nut, and use a 17mm open ended wrench to hold the fuel filter. position both wrenches like scissor style, then squeeze both wrenches with both hand, always works well for me.
http://mysite.verizon.net/vaio338168/avator.jpg
2002 2AZ-FE, LE Phantom Grey Pearl, Retrofitted with LS430 Projectors on SE Headlights. Aftermarket Foglight
bronzemaxell is offline   Reply With Quote
Old 06-22-2011, 06:27 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
^ +1
that's how I do it too (like Bronzemaxell described), works every time, no matter how many miles...
