Click sound from my steering wheel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-22-2011, 02:11 PM   #1 (permalink)
View dipeshks's Photo Gallery
I have toyota camry 94 coupe V6 engine. I changed my power steering fluid a month ago, after that time onwards I have been experiencing a problem of click sound when I turn my steering wheel sharply towards right. This sound doesn't appear at the highway when I am turning but only appears at the situation when I am driving less than 5 miles and I turn right sharply. The sound is more like - "tak tak tak tak tak".
I dont know what the problem is and what to do for troubleshooting. I also want to know if this case is serious and whether or not I can drive my car without fixing it!
dipeshks is offline   Reply With Quote
Old 06-22-2011, 02:19 PM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
It's most likely the left (driver's side) CV joint going bad. Unrelated to the PS fluid change.
BMR is offline   Reply With Quote
The Following User Says Thank You to BMR For This Useful Post:
dipeshks (06-22-2011)
Old 06-22-2011, 02:36 PM   #3 (permalink)
It might be really expensive to change the CV joint right? Does it bring a serious problem if I don't fix it at this time?
Old 06-22-2011, 04:14 PM   #4 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
The Axles aren't that expensive. They generally run $80-$150.00 for them.
If you dont replace it, if your axle breaks your car isnt going to move and will need towed.
The Following User Says Thank You to Mister_Perkins For This Useful Post:
Old 06-22-2011, 04:31 PM   #5 (permalink)
Posting via iPhone/iPad
CupCate18's Avatar
Gameroom cash: $373364
View CupCate18's Photo Gallery
Sounds like CV joints/axels. Take off your front wheels and take a look at them.
RWD 5-speed Zoom-Zooms
My car has less body roll than I do.
When you want sports car handling, you buy a sports car.
CupCate18 is offline   Reply With Quote
The Following User Says Thank You to CupCate18 For This Useful Post:
Old 06-22-2011, 05:29 PM   #6 (permalink)
Additional thing click sound
Also, before the sound came in there was a puff sound(loud one) when I turned my car towards right. I pull over my car into my parking lot and saw there was nothing wrong but that time onwards I had the clicking sound coming into my car.
Old 06-22-2011, 05:33 PM   #7 (permalink)
When I think "Puff Sound" I think air .. is this a correct thought process ? or are you trying to describe a different sound.
Your best bet would be to run the car up onto some car ramps, and grab a hold of the axles. If they are in-deed bad, then when you push straight up and pull down next to where the rubber boots are (but grabbing a hold of the center axle piece) and it pops up and down quite a bit, your axle is going to need replaced. If they are tight, then you have another issue.
Old 06-22-2011, 05:54 PM   #8 (permalink)
It was alike the sound as if when a car hits another car.
The puff sound came before and after that it was followed by the click sound(after puff sound was heard, then started the problem of click sound on the steering wheel of the car)
Old 06-22-2011, 05:59 PM   #9 (permalink)
Well, I would still do what I said above as far as driving the car onto ramps and checking the axles. if they move up and down, they are bad. They will move side to side a little, so dont let that scare ya
Old 06-22-2011, 08:16 PM   #10 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Just a wild guess, but the puff noise maybe was the CV boot ripping open? Like others have said, take a look under there and see if that's what it is. If the boot's torn you'll find heavy sticky black grease spewed all over the wheel/brake/suspension area.
Old 07-01-2011, 06:26 PM   #11 (permalink)
I took my car to the mechanic yesterday and he told me that the car was fine. He told me that supposedly the sound was due to low pressure in power steering pump. Also, the puff might have happened due to low pressure. I dont know and right now the car is not making sound at all. Strange!
