Very Impressed with Headlight Restore Kit (pics) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-22-2011, 09:14 PM   #1 (permalink)
View nathanours's Photo Gallery
Hey all, I recently went to Auto Zone and noticed they had Turtle Wax brand headlight restore kits on sale for only $6. My headlights were completely foggy looking and not clear at all. There was no yellowing, but the kit says it also works for that as well. Anyway, I was thrilled with how well my car looked after it was done. These are the original 14 year old headlights, and this took about an hour of work. Just wanted to let anyone know about this that may have headlights that looked like mine. Sorry, no before pics, I wasn't expecting much, but here are the results:
nathanours is offline   Reply With Quote
Old 06-22-2011, 09:58 PM   #2 (permalink)
Camry Noob
View Disturbed Edge's Photo Gallery
Look great. I bought a kit awhile back with good results as well. Noticed over the years after doing the sanding and buffing jobs they seem to haze over after a few months so I started clearcoating mine.
1993 Camry LE V6
1991 Civic Hatchback DX I4
1997 Explorer XLT V8 AWD
2004 Ranger Edge V6
Disturbed Edge is offline   Reply With Quote
Old 06-22-2011, 10:02 PM   #3 (permalink)
Lighting Specialist!
iovaykind's Avatar
Gameroom cash: $480582
iTrader Score: 8 reviews
View iovaykind's Photo Gallery
Looks good! Just hopefully it won't yellow quickly.. because it might, now that the top protective coat is gone
iovaykind is offline   Reply With Quote
Old 06-22-2011, 11:04 PM   #4 (permalink)
The kit comes with its own special sealant you apply that is supposed to be good for 5 years to prevent yellowing. Even before though, they were never yellowed at all to begin with, only foggy.
I would not mind spending $10 a year even to keep em looking like new though. You seriously sand off only about 1/3 of a mm of material out of around half an inch so you'd be good using a kit like this about 15 times I'd guess before the material gets too thin. The sealant dries and sort of adds a layer of thickness as well.
Old 06-23-2011, 01:02 AM   #5 (permalink)
Died around age 230, XXX
96ToyoCam164K's Avatar
View 96ToyoCam164K's Photo Gallery
I don't know...I tried the sanding thing and it made my original headlights all chalky.
I find it easier to just order new ones from online for $46 LOL. Makes the car look brand new.
From experience, most of the extremely yellow headlights are from water in the inside.
96ToyoCam164K is offline   Reply With Quote
Old 06-23-2011, 08:24 AM   #6 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
We use a kit at my workplace for clearing the headlamps. It works really really good.
Comes with a foam block, wet / dry sand paper, Silicone / wax Removing Spray, microfiber cloths, clearcoat, and High powered lights on a stand.
you spray the silicone / wax removing spray on it liberally and then wet sand the headlight ... then once you wet sand it and get the light evenly sanded, you grab the microfiber cloth and wipe it down. Then spray the clear coat on it, and grab the light stand it comes with and put it one each head light for 7 minutes to allow the headlight clearcoat to harden.
Very Effective, and the headlights look like new. Thanks for sharing, Headlight looks really good!
Old 06-23-2011, 09:30 AM   #7 (permalink)
double dose camry
View mail2_jb's Photo Gallery
I used a Meguairs kit from walmart ($15) and am really impressed with it (~10min per lense to clean it). It doesn't come with clear coat. Just their plastiX scratch remover, microfiber and a polishing pad that you attach to your drill. It is been going strong for 2 years now, I started to see little bit of fading now.
mail2_jb is offline   Reply With Quote
Old 08-12-2011, 09:52 PM   #8 (permalink)
View Jawadali's Photo Gallery
Does the Turtle Wax kit require a drill or any other special tools?
I have been meaning to do this to my headlights too, as they have gotten quite foggy. I have heard decent things about the 3M kit, and have seen the Meguairs , but it requires a drill. Since I just moved, I don't have a drill (or any other real tools, for that matter).
Jawadali is offline   Reply With Quote
Old 08-12-2011, 11:47 PM   #9 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
I use Turtle Wax kit from Autozone too. the pads are good and reusable, almost indestructible
Used it like 6-7 times already and still have 50% left of both the wet sanding lubricant and the rubbing/wax compound.
Posted my pics here some time ago:
review: Turtle Wax head light lens restorer kit
good kit. I like it.
I heard that pads in 3M's kit get destroyed easily. I never tried the kits for a drill, always used my own elbow (~10-15 mins per lamp does the trick).
I like the outcome on OP's car, lamps look great!
