Removing the Climate Control Unit
Hi BunnMan. I know you posted this 6 months ago, but I just did this the other day. The trick is that you don't have to remove the Climate Control Unit to change the bulbs. You just have to remove the screws on the left and right and pull the unit out as far as it will go . . . which is not far.
You then have to remove the chrome colored screw from behind the left most dial. Then you only have to remove the face plate of the unit. It's a little tricky, but it will eventually separate from the unit. Now you will see the two bulbs that need to be replaced.
1996 V6 Camry 150K
