97 camry le. will the 6cyl engine fit in 4cyl model? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2011, 10:22 AM   #1 (permalink)
View bigblind popper's Photo Gallery
title says it all. i need a new engine and the 6cyl are much cheaper than the 4cyl for the 97 camry le. will the 6cyl engine fit in the 4cyl model? sorry if its a repost or a stupid question. i dont know much about cars.
many thanks in advance
bigblind popper is offline   Reply With Quote
Old 06-23-2011, 10:44 AM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
yeah it will fit, but you gotta change a lot of crap including the wiring harness, ecu, shift linkage, axles, motor mounts
Old 06-23-2011, 10:48 AM   #3 (permalink)
Post
so i assume all that stuff will cost more than a thousand bucks right?
the v6 is 600 the v4 is 1600
my brother is doing the work so labor isnt too much of an issue.
Old 06-23-2011, 10:49 AM   #4 (permalink)
lol definitely more than $1000.00. You cant even get a motor and transmission for under $1000.00 (You will also need the 6cyl. transmission).
to do a complete swap, your probably looking at
$600.00 for the motor
$600.00 for the transmission
$150.00 for the ecu
$100.00 for the engine harness
$80.00 for the dash harness
$70.00 for the Cluster
$200.00 for the motor mounts
$100.00 for the fan assembly
$50.00 for the power steering pump (Runs fans)
$30.00 for the shift linkage
I may be missing some stuff, but lets see the total:
$1980.00 * .06 for florida sales tax = $2098.00
prices may vary, just giving you a rough idea of what u will need to get. It makes more sense just to go with what u got already
Old 06-23-2011, 11:02 AM   #5 (permalink)
thank you very much for the info! i appreciate it. one more quick question if you dont mind. If i do a v4 to v4 swap do i need to purchase anything besides the engine?
and i meant will the stuff besides the engine cost more than a grand, not the whole project. but your numbers show it does so you answered the question. thanks again.
Old 06-23-2011, 11:04 AM   #6 (permalink)
nope, if u get the 4cylinder it will be a direct swap.
only thing you might want to do is replace the timing belt, water pump, tensioner, timing seals (cam and crank), and rear main seal.
