how do i restore my wiring harness - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2011, 11:15 AM   #1 (permalink)
dorifuto.boi's Avatar
Gameroom cash: $171700
View dorifuto.boi's Photo Gallery
hey,
my wiring harness is ripping apart.
im going to replace the oem wiring loom with new fire retardant wiring loom. im going to tape up the new wiring loom with 3m wiring harness tape.
for those 1 or 2 wire plugs, the factory doesn't use wiring loom to protect it. they use some kind of really thin hollow rubber/plastic tubing. does anyone know where i can get this ? (for example look at the horn plug behind the grill. it isn't protected with a loom but with the really thin hollow tube)
thanks,
d
http://web.ics.purdue.edu/~dfung/car.html
^^^ List of my mods
dorifuto.boi is offline   Reply With Quote
Old 06-23-2011, 11:34 AM   #2 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
I replaced the hollow loom with regular loom because some mice ate alot around engine. I used a razor blade to cut out the old loom.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 06-23-2011, 11:43 PM   #3 (permalink)
does it work pretty well ? the only reason i didn't want regular loom was cause it doesnt bend very easily where the hollow loom is more bendable
^^^ List of my mods
Old 06-23-2011, 11:50 PM   #4 (permalink)
Avy
Yes it's bendable, it comes circled up in the package. I used it around the radiator fans on the fan harnesses, with no problem.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 06-24-2011, 12:23 AM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
you can get various kinds of wire protectors (heat shrink tubes, plastic flexible pipes and such) at local Harbor Freight Tools cheap in electrical section, as well as all needed tools, butt connectors, solder guns, tape, wires and such...
Old 06-24-2011, 07:31 AM   #6 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
I like using the hard plastic loom that is originally around some of the wires on the engine. Ill post up a pic in a bit.
Works great and is easy to install, just twist it on
