Power Steering - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2011, 07:19 PM   #1 (permalink)
View blackhawk1109's Photo Gallery
Power Steering
So my friend decided to top off my ps with just regular ps fluid, around 12oz were put into the reservoir. I have read a lot about the mixing of ATF and PS but would like just a straight forward answer. Should I flush my system 100%? Can I just empty reservoir and top off and repeat after a certain amount of miles? Best ATF for this situation?
Thank you for answer and I apologize if it is a repetitive post, I have searched.
blackhawk1109 is offline   Reply With Quote
Old 06-23-2011, 08:30 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Was the PS fluid listed as being compatible with your car? Lots of times, about the only difference between PS fluid and ATF is the lack of red dye in the PS fluid. It's not like the PS system is particularly picky -- as long as it's a hydraulic fluid of more-or-less the right viscosity that doesn't eat your hoses, you're OK.
Don't do the opposite, 'tho -- auto trannies do tend to be particular about the fluid you drop into them. And they abuse their fluids a lot more than the PS system does.
Old 06-23-2011, 11:07 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
You can do this:
http://www.toyotanation.com/forum/t19334.html
using Walmart's SuperTech Mercon-V, Castrol Import Multi-vehicle ATF, or Mobil-1 ATF. I wouldn't use dino Dexron III type ATF because of the small price difference.
Old 06-24-2011, 07:39 AM   #4 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
The ps fluid will harm your seals. I would pull off the return line on the ps rack that goes back to the reservoir and start the car up and turn the steering wheel side to side collecting it in a container. Topping the reservoir off with ATF as it goes down. Do this until the ps fluid has dissipated
Old 06-24-2011, 02:35 PM   #5 (permalink)
A camry n00b
peshwa's Avatar
Gameroom cash: $257859
View peshwa's Photo Gallery
I used PS fluid to top off and it has nearly destroyed my passenger side PS rack boots! I am having a nightmare driving my beloved car with the sweltering summer heat. I have already used 1.5 bottles of Lucas stop leak and it worked fine in the winter. But summer ...no way...I have to find some ATF fluid that "stays thick" at ~150 degrees. Always use synthetic DEX-II/MERC for the Power steering on Gen 3 camrys.
1995 Camry DX L4 178,6XX miles and counting each mile.... acquired 05/25/2007 at 129K miles
2004 Mazda6 I4 5-Speed Manual 115,500 miles acquired 01/21/2011 at 109,XXX miles
peshwa is offline   Reply With Quote
