Gen3 changed to plastic water pump inlet?
OK, I'm a bit confused -- I've been getting a persistent small leak where my upper radiator hose goes into the inlet for the water pump (or thermostat housing...take your pick). The metal's pretty corroded, so I figured I'd just order in a new OEM one (part # 16321-03060) Just came in today, and it's a black plastic, instead of the original aluminum. Looks like it would fit OK, but seems like a pretty radical change. Engine's a 5S-FE from Japan, mfg date 5/95 (tag end of the 1995 model year run).
Did Toyota slipstream from aluminum to plastic sometime, or did both I and the parts desk screw up? Didn't think the system would even let that happen with the right VIN.
