cali or fed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2011, 11:16 PM   #1 (permalink)
View jayhood787's Photo Gallery
cali or fed
(7A650 5S-FE usa) doesnt say nothing esle on the sticker i got a 2000 solara 2.2 motor blown trying to buy used one but dnt kno if cali or fed
jayhood787 is offline   Reply With Quote
Old 06-24-2011, 12:16 AM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Unless it's fallen off, the underside of the hood of the car should have a sticker giving the vacuum routing diagram and the emissions spec.
Old 06-24-2011, 12:19 AM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
look at the exhaust manifold heatshield, if it looks like mine exactly then it's California emission specs:
Federal emission specs has the upstream oxygen sensor down there at bottom while California one has the Air Fuel Ratio sensor at the top part.
either way I haven't heard of or seen yet a Federal emission specs on any Solara sold in US/CA market, so it's probably California specs.
Old 06-24-2011, 07:21 AM   #4 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
It really doesn't matter what emissions it is. Just swap everything from your current motor to the new motor and you'll be fine. The motors are exactly the same
Old 06-24-2011, 02:42 PM   #5 (permalink)
Angry Help me plz
ive looked at the vac sticker under the hood and the emission label and all its says is 5S-fe usa.. and on the vac sticker it says USA & Canada.. N i dont have a heat sheild SO CAN SUM1 HELP ME
Old 06-24-2011, 03:10 PM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
it's very simple WHERE the upstream o2 sensor is located? at the top (like I said before, it is on any Calif model like mine) or down there at bottom (Federal). heat-shield itself is meaningless.
call the dealer if you have any doubts, I'm sure the Parts Counter guy will tell you exactly based on car's VIN which one it is.
Old 06-24-2011, 04:01 PM   #7 (permalink)
Gameroom cash: $326045
View adalex's Photo Gallery
hope this helps from my camry (but same engine) this is a federal engine
adalex is offline   Reply With Quote
