how do i tell what my bumper is made out of - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-24-2011, 12:06 AM   #1 (permalink)
dorifuto.boi's Avatar
Gameroom cash: $171700
View dorifuto.boi's Photo Gallery
hey,
my bumper is kinda broken
how do i tell what its made out of to determine the repair method ?
i know its not carbon fiber or fiber glass. it must be either urathane or that plastic thing right ?
thanks,
d
http://web.ics.purdue.edu/~dfung/car.html
^^^ List of my mods
dorifuto.boi is offline   Reply With Quote
Old 06-24-2011, 12:22 AM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
as far as I know it's plastic (not too specific sorry), so any kind of Bondo epoxy should do as far as cracks go.
some people also use a filler to cover dents, then put primer, matching base coat and clear coat on it.
using a hot air from hair dryer on dents in plastic bumper also help straightening them out.
Old 06-24-2011, 12:28 AM   #3 (permalink)
its not a toyota bumper
^^^ List of my mods
Old 06-24-2011, 01:44 AM   #4 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
Most bumpers are either urethane or ABS in terms of the plastic-y kinds. You say it's not carbon fiber or fiberglass and I'm assuming it's not steel or other metal either, so that leaves plastic.
For either type of plastic, you can use a plastic welder, fiberglass, or even bondo to fix cracks. Dents in plastic will have been set in by the sun, so getting them out usually requires heat and some way to affix them in the correct position while they getting set in said position.
Pictures?
Chris Crash is offline   Reply With Quote
Old 06-24-2011, 05:23 AM   #5 (permalink)
hey,
i thought that urathane has different repair procedures than plastic.
i ahve a few very small holes i need to fill as well as a flap missing that i have to probably use a mesh then fill the mesh
anyways heres a quick picture from my camera
^^^ List of my mods
