1MZFE Valve Cover Bolts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-24-2011, 12:13 PM   #1 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
I remember a very long time ago reading about how on the V6 camry, one or two of the valve cover bolts wasn't able to be fully torqued due to it bottoming out, so there was always oil leaking. The solution said was washers. I'm now doing rear valve covers and notice tons of oil leaking everywhere, and after searching and checking the stickies, I can't find the post!
Does anyone know which bolt or bolts needed washers? I don't want to add washers to the wrong bolt and have it not thread in enough...
Chris Crash is offline   Reply With Quote
Old 06-24-2011, 12:19 PM   #2 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $568901
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
Chris, I never had to add washers, I bought new, OEM washers. Those are crush washers. I think Toyota calls them washer plates? The P/N is 90902-02001. Also, be very careful about torquing the bolts. I've heard of people breaking the bolt heads off trying to torque them to factory specs. You might want to order a few just to have them on hand!
I replaced the gaskets in february and no oil leaks
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
projektvertx is offline   Reply With Quote
Old 06-24-2011, 12:59 PM   #3 (permalink)
2001 Camry XLE 1MZ-FE
View ajkalian's Photo Gallery
I just added 2 washers to all the old bolts and torqued them to specs, 72 in/lbs or 6 ft/lbs IRRC. It wouldn't hurt to pick up some spare bolts next time you are at Pick-N-Pull. Or you can get them new, at like $2.30 each. Way too much for a bolt, if you ask me. They are real easy to break, once they have been overtorqued.
Plus I smeared gasket sealer on all the surfaces, not just a few as the FSM says to do.
Here's a couple of the threads, there's probably more though.
http://www.toyotanation.com/forum/sh...63#post2612663
OEM VS Felpro Valve cover gasket
2001 Camry XLE, 6cyl, 1MZ-FE, 91,000 miles.
ajkalian is offline   Reply With Quote
Old 06-25-2011, 01:36 PM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
It's either new OEM bolts with wavy washers or just put a regular Home Depot washer on there. One should do fine, but Ajkalian used two. Just add a washer to each bolt. To all of them, including those that don't leak, yet.
And make sure to properly torque down the bolts in a star pattern. And recheck after 15 minutes. HF has those 1/4" torque wrenches on sale often ($12.99 or so with mailer coupon).
I'd also change out the PCV valve/grommet and reseal the semicircular plugs while you have things apart. Permatex Ultra Copper or Ultra Black are fine. Just make sure the surfaces and clean and free of oil (otherwise RTV won't stick).
Old 06-25-2011, 01:46 PM   #5 (permalink)
Yup just picked up some flat washers at lowes for 60 cents. The PCV valve was completely missing, well, half was in the valve cover but I was able to extract it.
Just waiting on my next day at work to get my parts!
Old 06-25-2011, 04:51 PM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
Chris if you want OEM crush washers for VC bolts, then let me know I have 8 extra on me. Ordered them on top of new OEM bolts, but wasn't aware that new bolts come with new washers.
flat washers will work only if you stack them like 2-4 of them at once. OEM crush washers are one time use only. torque them to specs.
Old 06-25-2011, 05:10 PM   #7 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
When I bought some, the bolts came with the washers so its one part.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 06-25-2011, 06:05 PM   #8 (permalink)
抵抗は無駄です
fenixus's Avatar
^ok, all clear, thanks.
Old 06-25-2011, 09:42 PM   #9 (permalink)
redneck engineer
lemegacool's Avatar
Gameroom cash: $233405
View lemegacool's Photo Gallery
i'm doing the vc gasket on mine soon and i will be adding 2 stainless washers to each bolt before torquing it down... i think thats what the guy did so the bolts doesnt bottom out and snap before reaching proper torque
1994 camry v6 5 speed swapped
holset hx35w rebuild/polishing in progress :P
cardomain: http://www.cardomain.com/ride/3872430
lemegacool is offline   Reply With Quote
Old 09-05-2011, 04:15 PM   #10 (permalink)
View optimist81's Photo Gallery
May I ask a silly question? So in order to change the new bolts for the rear valve cover gasket for "V6" camry solara, I need to remove the manifold over the it, right? It seems hard for beginners. :P
optimist81 is offline   Reply With Quote
Old 09-05-2011, 04:35 PM   #11 (permalink)
Yup. It's a pain.
Old 09-05-2011, 04:42 PM   #12 (permalink)
Thanks. Chris. Then, I'll bring the new OEM bolts to the autoshop.
Yup. It's a pain.
Old 09-05-2011, 04:50 PM   #13 (permalink)
抵抗は無駄です
fenixus's Avatar
yeah, I would just get new OEM bolts (they come with new crush washers), don't re-use the old ones, they are brittle and may shear off, same about crush washers, don't re-use, you need new ones every time.
