There's really no maintenance schedule for these, but putting in new brake fluid and power steering fluid helps. You don't have to pay to do these if you don't want, there's some DIY stickes on here for those.
Double check your filters, do the fuel filter if it hasn't been done in awhile. Do a general inspection under the car, check for things like leaking/bas struts, a leaking CV boot, bad ball joints, etc. This is about the time where things like that start to go, but it doesn't mean you have to change them all immediately, you can hold off for a bit, and some projects like that are pretty straightforward DIY as well.
Also, what about spark plugs?
6 speed manual 2011 Camry SE 2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
