Need Tips to remove the EGR valve on 2001 Solara 5sfe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-24-2011, 07:58 PM   #1 (permalink)
Toyata and Mazda owner
View devilxavierz's Photo Gallery
USA Need Tips to remove the EGR valve on 2001 Solara 5sfe
I was trying to remove the EGR valve so I can clean it. I got the 2 nuts off that connected to the intake but I was having a very hard time on taking off the one that connected to the EGR tube. It has a very tiny space. I could fit my socket in but I couldn't pull it. It literally took me 2 hours.....
Any tip that I can take that piece of shit out?
1986 RX7 NA
2001 Solara SE
2008 Camry LE
devilxavierz is offline   Reply With Quote
Old 06-25-2011, 01:21 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Use the box end of a combination wrench on the bolt, and turn the wrench by a hex-bit socket on the open end with an extension and ratchet. Watch the direction so you don't end up tightening.
http://www.harborfreight.com/6-piece...set-67891.html
Old 06-25-2011, 04:55 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
do you mean the 10mm bolts to EGR exhaust pipe? I f yes then you can do them once you removed the valve together with pipe off the car. just unboltthe bottom end of that pipe from engine head. you will need a crescent key, like 6'' will do, it worked for me, but it takes a lot of elbow grease to remove the union nut (or whatever it's called) ... I actually could barely use my hand wrist for next week after removing and re-installing it ...
word of caution though, those damn 10mm head bolts from EGR valve to pipe like to rust and snap on loosening, so be careful.
Old 06-27-2011, 08:01 PM   #4 (permalink)
yeah, that's exactly what I meant and that damn thing is so tiny and the space is so little, once i fit a socket in their, i can barely turn that wrench. So your suggestion is to get under the car and remove the EGR tube?
1986 RX7 NA
2001 Solara SE
2008 Camry LE
Old 06-27-2011, 10:22 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
yes that's what I had to do after snapping one of those bolts while trying to unbolt EGR valve on engine
Old 06-28-2011, 12:11 AM   #6 (permalink)
the bolts that attach on the intake is not a big deal but the one that secure the tube and the valve is stupid. Im thinking of doing a EGR delete, suggestion?
1986 RX7 NA
2001 Solara SE
2008 Camry LE
Old 06-28-2011, 12:13 AM   #7 (permalink)
And because of that, my CEL is on and threw me P0300,P0401,P0402. All cause by this piece of shit
1986 RX7 NA
2001 Solara SE
2008 Camry LE
