Broken Sway Bar bracket bolt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-26-2011, 01:28 PM   #1 (permalink)
Gameroom cash: $123900
View dave1811's Photo Gallery
4th Generation Broken Sway Bar bracket bolt
Was trying to replace the sway bar bracket bushings on my 99 Camry 4 cylinder w/173K miles. The first bolt I tried to unbolt broke at the bracket level. Had soaked it in PB Blaster but I guess not long enough. Any suggestions on how best to get it out? Very frustrating, almost makes me want to just take it in and have a shop replace them & the sway bar links. I hate rust!
99 Camry (141k miles-At the graveyard now!)
99 Camry (161k miles)
02 Sienna
dave1811 is offline   Reply With Quote
Old 06-26-2011, 02:50 PM   #2 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
Rent a tap and die set and go to work on it.
RichieRichJP is offline   Reply With Quote
Old 06-26-2011, 04:33 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
go to Harbor Freight Tools, get a set of left hand drill bits and a cordless drill 18V at like $12 on promo (up to $39 regular), get also a spring loaded Center Punch tool.
http://www.harborfreight.com/13-piec...set-95146.html
http://www.harborfreight.com/18-volt...uck-67024.html
http://www.harborfreight.com/spring-...punch-621.html
punch a hole in broken stud, right in center with a Center Punch. start with small drill bit (not smallest) and start drilling straight through on reverse. when you have a small hole, switch to bigger drill bit and so on, until the stud catches and starts spinning out.
use LOTS of PB Blaster before you start, and keep drill bits covered in e.g. motor oil, it helps.
removed a few studs/bolts like that easily.
if you end up with a broken bolt/stud and a big hole in it and it still won't budge, then get an extractor set with T-handle and remove it manually, it will go eventually.
http://www.harborfreight.com/12-piec...set-40349.html
T-handles
http://www.harborfreight.com/3-piece...hes-38560.html
good luck!
Old 06-26-2011, 04:45 PM   #4 (permalink)
4th Generation
Thanks, I might try both of those suggestions after calming down a bit. Already have a cordless 18V Dewalt drill, a Dewalt Hammer drill and a regular corded drill. I hate to think that other 3 bolts are in the same condition. It looks like they have a nut welded on the back part of the bracket or so. I will see how I feel tomorrow and might tackle it then. Thanks for the encouragement! Next Camry I buy I think I will look at ones from "raised" in West Texas, Arizona, etc. Maybe they won't have a ton of rust on them. Mine apparently did some time for a few years in Ohio when new with a rental car company.
Dave
02 Sienna
Old 06-26-2011, 05:25 PM   #5 (permalink)
View Natedawg's Photo Gallery
remove the bracket from the subframe. take it to a shop have them bust the nut off with an air chisel.. that nut is tack welded on the backside. once it breaks off . nut and bolt it and call it a day.
Natedawg is offline   Reply With Quote
Old 06-26-2011, 09:23 PM   #6 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
mine sheared clean off too. nice to know im not the only one that had this problem.
Old 06-26-2011, 09:32 PM   #7 (permalink)
Gameroom cash: $202300
View zppeacock's Photo Gallery
Most of these gens will snap, air chisel trick works the best. Rust belt baby.
1990 Camry Wagon, 270k, Gray, Retired
1993 Corolla Wagon, 231k, White, w/White Tenzo R's
1994 Lexus ES300, 141k, Pearl White, IS300 Rims
1973 Chevy C20, 76k, Metallic Green, 454 BigBlock
1994 Lexus SC300 1jz 61k Black
zppeacock is offline   Reply With Quote
Old 06-26-2011, 10:15 PM   #8 (permalink)
4th Generation
I bought me an IR impact wrench around 6 months ago. Probably time to buy an air chisel (another excuse to buy another tool). And if I do that, will probably need a bigger compressor. Just collecting more tools to pass onto my son in about 5-10 years or so. Thanks for all the positive comments!
Bed time!
Dave
02 Sienna
