Removal: Rear Door Power Lock 99 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-26-2011, 04:27 PM   #1 (permalink)
View ed0628's Photo Gallery
Power Door lock on Left rear is inoperative. Removed door panel to access the connector to test for presence of voltage. Space is very limited, cannot remove connector. Looked for fasteners to remove the solenoid for off-car test, no way.
Hanes has not helped much. Unless I have missed it, I can't find any info on removal.
I would appreciate your help with this problem.
ed0628
ed0628 is offline   Reply With Quote
Old 06-26-2011, 04:47 PM   #2 (permalink)
99 Camry should be 98 Camry, SORRY
My Camry is a 1998 , sorry about the error. My other car is a 1999 Dodge Caravan. Looks like I may be off to a bad start!
ed0628
Old 06-26-2011, 05:10 PM   #3 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
Ed,
The FSM does not go in detail about the solenoid either, but from the looks of it, you need to remove the whole lock assembly (where it meets the striker plate) and pull through the service hole in the door (covered by plastic). Then you should be able to unclip the connector and remove as a whole.
Chris Crash is offline   Reply With Quote
The Following User Says Thank You to Chris Crash For This Useful Post:
ed0628 (06-26-2011)
