Ashtray light? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-27-2011, 10:44 AM   #1 (permalink)
View rebuy's Photo Gallery
Ashtray light?
Does a 97 Camry have a light in the ashtray area?
Where is it?
rebuy is offline   Reply With Quote
Old 06-27-2011, 11:09 AM   #2 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
Pull off the console surround, pull out the cd player, unhook the cable with the light, replace light, put everything back together.
The light isn't hard to find. The ashtray has a cut out to allow the light to shine in...
RichieRichJP is offline   Reply With Quote
Old 12-30-2011, 08:02 AM   #3 (permalink)
View gtchamp7's Photo Gallery
Sorry to open up an old thread, but I couldn't find an answer on Google.
What size is the light bulb for the ashtray? Also, what is the size of the light bulb for the ring around the cigarette lighter?
Thanks!
EDIT: I forgot to mention it but I am referring to a '97 Camry, like the original poster was.
gtchamp7 is offline   Reply With Quote
Old 12-30-2011, 10:32 AM   #4 (permalink)
I do not have a CD player, I have not found the light yet. Still not sure what to do.
Old 12-30-2011, 01:45 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
you need to remove the ash tray and pry out the console trim around it. on my car it's just clipped in there, no screws.
once you detach the trim GENTLY, you should see the cable with light bulb in it attached on top of bracket for the ashtray.
bulb is a regular tiny something every parts store sells (bring it in there they will find a match), any color to it is caused by some other thing like green plastic or rubber boot around it.
