Burning oil, not sure if valve stems or piston rings - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-27-2011, 07:46 PM   #1 (permalink)
Lord of the Sith
Gothmog3VZ's Avatar
Gameroom cash: $391902
iTrader Score: 6 reviews
View Gothmog3VZ's Photo Gallery
Hey guys! Got a bit of a glitch here...
As some of you may know, I've been planning a twin turbo build for my car (actually doing it, already bought turbos). However, there's a small glitch.
My car has recently started burning oil on startup - Dad noticed when I left for work yesterday that it was burning when I left the driveway. Now, this only happens on startup when the engine is cold - if the engine is warmed up, she runs A-OK! Talking with LeMegaCool, think it's either piston rings, or possibly valve stems. Wondering how to tell which it is without tearing apart the motor, compression test would tell for piston rings, but not sure if a valve-stem-seal issue would interfere with it. Kind of important too, because if it's piston rings, then I may as well just buy a new motor for my build...
Any help is greatly appreciated!
1993 Toyota Camry 3VZ 5-Speed
(Beige Beluga)
1989 Toyota MR2 3S-GTE 5-Speed (Din)
Need performance parts?
Shoot me a PM, I'll see what I can do
Gothmog3VZ is offline   Reply With Quote
Old 06-27-2011, 08:40 PM   #2 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Sounds like valve stem seals. How many miles on the engine? What are your compression numbers?
Turbo on an aged motor will just quicken its demise. At a minimum I would do a light rebuild (rings, bearings, gaskets). Im sure you know that already though.
carsrus is offline   Reply With Quote
The Following User Says Thank You to carsrus For This Useful Post:
Gothmog3VZ (06-28-2011)
Old 06-27-2011, 08:46 PM   #3 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
I think for a serious twin turbo build, regardless, you should plan to rebuild.
Chris Crash is offline   Reply With Quote
The Following 2 Users Say Thank You to Chris Crash For This Useful Post:
Gothmog3VZ (06-28-2011), projektvertx (06-27-2011)
Old 06-28-2011, 11:51 AM   #4 (permalink)
Lord of the Sith
Gothmog3VZ's Avatar
Don't know yet, will probably go to my dad's mechanic for test sometime this week (don't have the equipment to do that at my place)
engine has 274k km (so about 160k miles, rough guesstimate).
Yeah, I think I'll probably just save up my money and get the engine rebuilt, postpone the turbo build for a bit. Getting a shop to do it would be $1-2k, from what I've read, so I'm going to research, and see what I can DIY - if I wind up rebuilding it, I'll probably go the whole 9 yards, get forged pistons and stronger valve-springs, do it once and do it right.
any recommendations for parts, brand wise? (other than OEM)
(Beige Beluga)
Old 06-28-2011, 01:54 PM   #5 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
ide recommend Felpro
But yeah , I agree with the consensus and I say that your stem seals are leaking a little bit. When the motor heats up, its probably expanding everything sealing the crack up until it cools
The Following User Says Thank You to Mister_Perkins For This Useful Post:
Old 06-28-2011, 04:43 PM   #6 (permalink)
redneck engineer
lemegacool's Avatar
Gameroom cash: $233405
View lemegacool's Photo Gallery
if i had time we could meet up in a parking lot and do a comp test on the front banks but i'm really busy this week i'm going to replace o2 sensors in a buddy's car 45min away tonight... maybe tomorrow... or if your dad'S mechanic is going to do it for free then go for it
thing is do you have a spare car? rebuilding the engine will put you car down for some time... need to strip the engine first to measure what kind of bearings/pistons youll need for the rebuild... then order parts and wash/machine the heads/block and rebuild the head..
1994 camry v6 5 speed swapped
holset hx35w rebuild/polishing in progress :P
cardomain: http://www.cardomain.com/ride/3872430
lemegacool is offline   Reply With Quote
The Following User Says Thank You to lemegacool For This Useful Post:
Old 06-28-2011, 05:51 PM   #7 (permalink)
Lord of the Sith
Gothmog3VZ's Avatar
I'd love to tomorrow, but I've got work from 10-8 (ah well, it'll pay for the parts, so no complaints). Going to pass by his mechanic tomorrow and see if/how much they'll charge for that.
I don't have a spare car, but I usually travel to school via bus (saves the headache of finding parking and paying $400/year for a decal), and I'll borrow parent's cars for everything else, so it's not a terribly huge inconvenience.
(Beige Beluga)
