92-94 compressor is different than 95-96. thats the problem
92-94 is R12 compressor
95-96 is R134a
You can try to remove the top section of the compressor and swap them over (they are removable) ((Where the lines hook up))
Originally Posted by carsrus
Just a heads up. I know using a torque wrench seems cool, 99.9999% of everybody doesn't use them on jobs like this. It will only cause you problems, just what you are describing.
Over-torquing is a problem 99.9999% of the time
an accurate torque wrench will not allow this to happen if torqued to the proper spec.. But I agree, I never use a torque wrench when bolting stuff like a compressor up.
