96 camry 2.2 l
After Removed oil pump pulley, noticed black rubber on the oil pump shaft. Took a screwdrivr and hammer, was able to move the gasket 360 degrees around the shaft. pieced most of it out, realizing i made a dent in the oil pump shaft. there is still black rubber in there that i can not get out.
Did the dent damge the shaft?
CAn i loosen the 12 oil pump bolts, without dropping oil pan to get to the rest of the rubber ?
this car has over 200K ,5 or 6 oil leak spots on driveway which i am trying to fix
