Sensors...2001 Camry V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2011, 03:52 PM   #1 (permalink)
View greyfellas's Photo Gallery
2001 Camry V6: about a month ago check engine light came on with code P1135 A/F Sensor Heater Circuit (Bank 1 Sensor 1), which I had replaced by dealer. Yesterday check engine light came on again with code P1155. Advanced told me code P1155 is the Air/Fuel SensorHeater Circuit (Bank 2 Sensor 1).Can anyone tell me the Denso part number so I can purchase this myself?
greyfellas is offline   Reply With Quote
Old 06-28-2011, 04:06 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Assuming this isn't a California-spec car (sticker on the underneath of the hood should say), the Toyota P/N 89465‑33180-- should be easy enough to xref. Or you could just punch in your info over at Rockauto -- they should list the proper Denso unit for your rig.
Last edited by hill8570; 06-28-2011 at 04:07 PM. Reason: Thumb-fingered the part number...
Old 06-28-2011, 04:11 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
http://www.densoaftermarket.com/catalog/catalog.php
for Denso part numbers, pick OE for the P'n'P application with no soldering or splicing. buy them on ebay or amazon cheapest.
Right one refers to Bank 1 Sensor 1 upstream (by firewall/windshield)
Left one refers to Bank 2 Sensor 1 upstream (front of car)
Rear one refers to post-cat (downstream, Sensor 2) sensor under car.
Old 06-28-2011, 04:31 PM   #4 (permalink)
Great, thanks fenixus! I've searched Denso and RockAuto (along with several others) but really needed the below explained:
Old 06-28-2011, 05:22 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
you welcome
