opinion ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2011, 12:10 AM   #1 (permalink)
View tmauldin's Photo Gallery
opinion ?
The chilton manual says to put silicone on the intake in certain areas, then put on the rocker arm cover / (valve cover gasket )
The valve cover gasket i bought says to not use w/ chemical adhesive
I did not use adhesive
What would you do?
tmauldin is offline   Reply With Quote
Old 06-29-2011, 12:39 AM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Not sure where on the intake the manual wanted you to use RTV (silicone), but even the factory service manual has you dabbing a bit of RTV where the gasket makes a sharp corner (it's not an adhesive, it's there to help out the gasket a bit). Wouldn't be surprised if you leak out at those corners over time.
Old 06-29-2011, 01:25 AM   #3 (permalink)
thanks, ill redo with RTV
