New radiator, now temp sensor leaks. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-01-2011, 07:58 AM   #1 (permalink)
View badappex's Photo Gallery
4th Generation New radiator, now temp sensor leaks.
Just replaced the radiator on the '99 camry (I4). Put everything back and now I notice he coolant weeping through where the temperature sensor bolts into. I tried to tighten, but fear too many turns will eat the threads. I've added an O-ring, even though my original never had one - and never leaked.
Anyone have luck using Permatex gasket maker? A thick coating may do the trick?
badappex is offline   Reply With Quote
Old 07-01-2011, 08:01 AM   #2 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
i've used the red permatex silicone on to make a gasket for temp sensor on the radiator, it must have been 3 to 4 years now, still ok.
but i did let it dried before filling the coolant.
http://mysite.verizon.net/vaio338168/avator.jpg
2002 2AZ-FE, LE Phantom Grey Pearl, Retrofitted with LS430 Projectors on SE Headlights. Aftermarket Foglight
bronzemaxell is offline   Reply With Quote
Old 07-01-2011, 08:36 AM   #3 (permalink)
Good to know. Unsure if yours was leaking or just a preventative measure. I plan on draining letting it dry overnight.
Old 07-01-2011, 08:46 AM   #4 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Doubt you'd need silicone...just a little sumpthin' on the threads should do the trick. The Toyota replacement part comes with something like Permatex Blue on the threads -- I'd just go with that.
Old 07-01-2011, 08:49 AM   #5 (permalink)
Don't know what the difference is between the blue and red, but will look into it when I pick one up. Just looking for the best sealer I can get for the threads. Apparently there is an Oring that helps, but mine never had it. So i need something strong enough to hold.
Old 07-01-2011, 09:29 AM   #6 (permalink)
when i replaced my radiator a few years ago, it was my fault i made the drain hole bigger than it was originally designed, don't ask me why i did that, i was just simply stupid, and even with the o-ring, i can see the gap, and it wasn't air tight, i didn't try to fill the coolant to see if it leaks, i went straight to use silicone around the drain hole opening, screw the sensor in. i was hoping it works, and it did.
Old 07-01-2011, 03:15 PM   #7 (permalink)
Picked up a tube of Permatex thermostat and water pump housing gasket maker. Supposably a good choice when dealing with coolant, Needs to cure 24hrs so Ill let you know.
Old 07-01-2011, 06:46 PM   #8 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
For those with o-ring seals a new o-ring should work (if the threads aren't damaged ).
For those without o-ring/washer, I typically use a teflon sealant, or as Haynes suggested - teflon tape.
http://www.permatex.com/products/Aut...ad_Sealant.htm
Old 07-01-2011, 08:47 PM   #9 (permalink)
I used teflon tape prior, but didn't help. So many Permatex choices, I may try the thread seal next.
