93 V6 SE, manual, hard bucking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-03-2011, 12:58 PM   #1 (permalink)
Tedders's Avatar
View Tedders's Photo Gallery
3rd Generation 93 V6 SE, manual, hard bucking
Hi, everyone.
I have a 93 SE V6, manual transmission sweety. It's bucking hard on first start up, that is, when cold and accelerating hard, the engine feels like it's cutting out, then in, then out. It makes the car buck like a mad donkey.
It lasts just a few times; sometimes I can make it stop by depressing the clutch and revving the engine.
When the engine's warmed up there's no problem.
So far I've:
Changed the cap, rotor, spark plugs, wires, checked for vacuum leaks, replaced the IAC valve with a new one (ouch!), checked the cold start fuel line (no problem).
Any intelligent ideas? Fixes?
Thanks!
Tedders
Tedders is offline   Reply With Quote
Old 07-03-2011, 01:03 PM   #2 (permalink)
Lord of the Sith
Gothmog3VZ's Avatar
Gameroom cash: $391902
iTrader Score: 6 reviews
View Gothmog3VZ's Photo Gallery
Video of the symptom could help...
I had an issue where the car did that last fall - turns out I got some crap in the gas tank while filling up, and it partially blocked the fuel line at some point, caused the engine to surge and buck if I went past 30% throttle. Seafoam took care of it for me, but if yours only does it when cold, not sure...
1993 Toyota Camry 3VZ 5-Speed
(Beige Beluga)
1989 Toyota MR2 3S-GTE 5-Speed (Din)
Need performance parts?
Shoot me a PM, I'll see what I can do
Gothmog3VZ is offline   Reply With Quote
Old 07-03-2011, 01:05 PM   #3 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426953
View EEngineer's Photo Gallery
change ur gear oil
do a seafoam
clean ur TB
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is offline   Reply With Quote
Old 07-03-2011, 01:17 PM   #4 (permalink)
Tedders's Avatar
Changed gear oil about four years ago;
Do a Sea Foam where?
What's a TB?
Tedders
Old 07-03-2011, 01:23 PM   #5 (permalink)
Lord of the Sith
Gothmog3VZ's Avatar
What's a TB?
Tedders
You basically have to suck in a bit through the vacum line on the side of your intake manifold (I'll post a pic in a bit to give you a rough idea, unless EEng beats me to it). about 1/3 of a can, but slowly so your engine doesn't hydrolock.
TB = throttle body.
(Beige Beluga)
Old 07-03-2011, 01:38 PM   #6 (permalink)
Tedders's Avatar
3rd Generation
Aaahhhhh... the Throttle body....
I last week sprayed it out with TB cleaner.
Sea Foammmmm....
Cannot wait.....
Tedders
Old 07-03-2011, 03:37 PM   #7 (permalink)
Born to Drive
EEngineer's Avatar
for ur problem, get a new fuel filter.
dump a whole bottle of seafoam in the gas tank when it's 1/4 full or even better 1/8th full.
drive it until it's really really empty.
done!
Rest in Peace
The Following User Says Thank You to EEngineer For This Useful Post:
Gothmog3VZ (07-03-2011)
