Headliner adhesive/glue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-04-2011, 02:27 PM   #1 (permalink)
View acprkit's Photo Gallery
I took the headliner out of a 1999 Camry to recover. I purchased some cotton fabric to cover it with, and used 3M Super 77 spray adhesive.
It looked great when I reinstalled it, but now the fabric is pulling down at the corners and in the middle after baking in the sun all day.
Is there a better adhesive? From what I have read about Super 90, it isn't much stronger.
Thanks for the help!
acprkit is offline   Reply With Quote
Old 07-05-2011, 03:39 AM   #2 (permalink)
View matt1mzfe's Photo Gallery
I did mine on a 99 too. I tried spray adhesive but even before putting it all back together it did not seem to stick too well. So I bought some glue called 'multigrip' which is a thick gel - used 500ml to do the job. I also cut the cloth larger than the backing board and wrapped it around the edges by about 2 inches all the way around. Mine has been fine for about a year including our summer - western NSW in Australia - so it is burning in the sun. The middle should be held up by the interior light as well as the glue.
To do the job well I had to take the roof liner out of the car alltogether - the first job was to rip off the factory fabric and then scrub all of the foam off the liner board. The factory cloth is stuck to a layer of foam which is stuck to the liner board - the foam decays and usually (in the 3 i have seen) it is the foam layer falling apart that lets the cloth fall down - its not the glue letting go.
It sounds like you tried to do the job in the car which I suspect is impossible to do properly, you might have to take all the trim off, light out, front window shades out and I found that removing the rear seat base made it easier to get the liner board out through without bending it too much.
matt1mzfe is offline   Reply With Quote
Old 07-05-2011, 12:49 PM   #3 (permalink)
re
Thanks for your reply. I did take the whole thing out, but stretched the fabric, which then popped off the headliner.
I bought sole weldbond, which I think is the same stuff. Its water soluble, but dries clear. Did you have any problems with bleed through?
Old 07-05-2011, 07:12 PM   #4 (permalink)
I didn't stretch the fabric at all. I bought different cloth - a quite heavy cotton upholstrey fabric - and it is black - almost so there is no visable glue - I don't think any came through the thick cloth.
I put the glue on the board and let it sit for a few minutes (which my glue said to do) before putting the fabric on. This meant the glue was more tacky - less runny when the cloth went on.
