Idle Issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-05-2011, 02:20 PM   #1 (permalink)
View blackhawk1109's Photo Gallery
Idle Issue
I have been having issues with my car in idle. Today i started it and it starts up at around 2000rpm. Slowly it goes down but after around 3 min it goes up to 2250 and stays there. I am still in park. I shifted the car into neutral and still up at 2250rpms. After shifting it into reverse it goes to rock bottom the rpm meter and stalls. After shifting it back into park and trying to start it up again it doesnt start. I try and give it gas but nothing. I will wait till it cools down and try again.
What might be the issues?
Recent fixes are cleaned my throttle, changed spark plugs, air filter, distributor cap and fuel filter.
blackhawk1109 is offline   Reply With Quote
Old 07-05-2011, 02:35 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Year of car? 4 banger or 6 banger? Was this problem happening before you cleaned the throttle?
Old 07-05-2011, 02:39 PM   #3 (permalink)
4 cylinder, 2.2 liter, 1992 Camry, 144k Miles. This specific problem no. Before cleaning the throttle it was stalling after going form a stop at a red light to accelerating.
Old 07-05-2011, 03:06 PM   #4 (permalink)
hill8570's Avatar
Check engine light on?
The high idle usually means you're getting a pretty good-sized air leak downstream of the throttle plate, although there can be other causes.
OK, the first two guesses are based on the "whatever you touched last caused the problem" rule:
First guess would be a vacuum line downstream of the throttle (on the throttle body) has been knocked loose. The fact that it's dying after being put into reverse should help narrow down which line, but I'm drawing a blank right now. There's not that many...check 'em all (both ends). Might even be able to hear the hissing on this big of a leak.
Second guess would be the IAC got gunked up when the TB was being cleaned...you'll get similar behavior when the IAC is stuck open. Should be able to id this easy -- with the car warmed up, stick your thumb over the IAC hole upstream of the throttle plate. Should pretty much kill the engine. If it does, it's likely the IAC needs a good flushing out (if it doesn't, see first guess).
A distant third would be the coolant temp sensor is reading too "cold", and your mixture is being set too rich. Should be able to check this (with the engine warm) by disconnecting the green connector up at the engine coolant outlet (where your upper radiator hose connects to the engine). If you're suddenly able to start and the engine idles OK, then it's the sensor (fail-safe on that sensor is "engine warmed up").
Old 07-05-2011, 03:14 PM   #5 (permalink)
Check Engine Light is Off
