the reverse connector female end can be ordered threw toyota(about $30). if they say if doesnt exist, go to someone else.
The colors are different from car to car. Sorry, that is how it is. My colors didnt match the instructions.
The Park/Neutral wires are correct.
With Wiring the reverse connector do not worry to much about which one is which. if you are not planning to use the park neutral switch, open it. when you open it you will see that that thing only completes a circuit. IN OTHER WORDS, all you need to do is close the circuit. To do this you need to put it into reverse. Can go either way.
2009 EX-L V6 6Spd MT w/Nav (stock for now)
1996 XLE V6 Camry, KSport GT Pro 9/7, TRD RSB, E153 5spd conversion, Gen 3 front end conversion, OBX Headers, Megan Cat Back, TRD M62 Supercharger
Supercharger whine > ex girlfriends whine
http://www.cardomain.com/ride/3329124
