Lights won't go off
Day time running lights and dash warning lights won't turn off even with the usual opening of the door ect. The dash warning lights stay on but they are dim. DTR lights stay on too. I can even run my A/C. Thought it was the ignition switch but ruled that out, EVEN THOUGH I cleaned up the back half of it and it worked for about 2 weeks. Then I swapped it out with my other Camry, no dice.
Car guy got it and changed out the ECU?? the $400 module. Seemed to work for a few days then back to the same of sheet. Have to get out and disconnect the battery. My theory is it has something to do with the DTR lights. Saw in a better manual that there is a module for it to the right side of the radio on the drivers side. Funny thing, I changed out the radio and again, it worked great for a while. So I'm leaning on that module or maybe the emergency brake switch that might have something to do with it?? I even checked the door switches. I'm baffled and out $600!! so far.
Next, is that test port on the top passenger side in the engine bay for testing your electronics?? Is there a tester to plug up to it that will read your electrical system like the ODBC reads the engine stuff??
