Interesting question, sorry I don't have the answer. An expert here can tell you the maximum allowable imperfections. Can you feel them with your finger? I took a quick look at the service manual, it states that the maximum warpage of the block surface is 0.05mm, and tells you not to scratch the surface when removing the gasket (duh).
I would do what carsrus suggests, use an abrasive pad and run it across the block a few times.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
