Just a few generic comments to assist you .... haven't actually removed that part:
1. get a so-called "prick punch" ... it has a hardened, sharp point ... strike the problem nut on its perimeter in a manner calculated to cause the desirable rotation of said nut. .... the impact must be on the outer most surface of the nut ... striking the center won't work. The sharp point will dig into the 'flat' of the nut.
2. If that doesn't work, find a GM dealer and buy a spray can of their penetrating oil ... expensive ... $12 or so ... but seems to be usually effective .... let soak for a while.
3. If still no success, find a propane hand torch and heat/cool the problem nut a few times .... use caution ... and moderation.
4. If still no luck, repeat steps 1,2,3 until something turns, breaks, or yields in some manner.
... no warranties are expressed or implied within this post
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
