Radiator cap blew today
So Im driving to work today and notice a bit of steam coming from the passenger side of my engine compartment and then realize that my temp gauge is basically maxed out. As soon as I notice this, the light turns green so I press the gas. The gauge immediately goes back to normal. I had to go about another 200 feet to get to my work so I pulled in and popped the hood. The cap to the overflow tank was not on all the way and it was letting fluid leak out. I then let the car cool and then removed the radiator cap... it is obviously no good at all. I checked the oil and it looks fine and clean. The fluid inside the overflow tank is dirty, but doesnt seem oily at all. Im feeling ok about this, but wanted to let others know my experience. I just got a new thermostat, some coolant, and a new radiator cap. Going to put the radiator cap and fluid in first, then drive home. If all is well, then I will replace the thermo this weekend and put some more fluid in. I wanted to get your guys' opinions to see if there is anything else I should look for...
Thanks in advance
