Passenger Window...dead? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-07-2011, 02:54 PM   #1 (permalink)
Mario Mobile
DM616's Avatar
Gameroom cash: $221100
View DM616's Photo Gallery
I'm not sure what to look for, and I'd like to fix this myself.
My passenger window will not roll down. I tried the master switch and I tried the door's switch, nothing.
If it was a broken wire I would suspect the the passenger door switch to work too but I don't think so.
Is there anything else to check besides the motor? And is it a simple task? I know how to take the whole door apart already so..
DM616 is offline   Reply With Quote
Old 07-07-2011, 04:20 PM   #2 (permalink)
RH window problem
The problem looks like it might be located within the RH window control switch.
Sometimes, moisture, humidity, or dust will cause a malfunction. Remove the wire connections from the RH window control switch. Use an electrical contact cleaner spray to remove any dirt or grease that might be causing the problem. Work the switch buttons a few times as you spray the cleaner.
Reconnect the wires to the switch terminals and see if that does the job .... or not.
If that doesn't work, you will probably have to get some sort of voltmeter and try to determine which point in the wiring circuit has a conduction problem.
I would get a can of actual contact cleaner .... Fry's or RS maybe.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 07-07-2011, 04:30 PM   #3 (permalink)
Mario Mobile
DM616's Avatar
So on the passenger side, if the switch is not connected at all, even the master switch won't move the window down?
Oh okay. Maybe this is my fault when I was putting my mirror back on if this is the case. I did check it once, and it worked then, but since then nothing.
I forgot to say my driver's door works fine, and I'm sure my back two work (can't test due to just getting tints)
Old 07-07-2011, 04:32 PM   #4 (permalink)
Lighting Specialist!
iovaykind's Avatar
Gameroom cash: $480582
iTrader Score: 8 reviews
View iovaykind's Photo Gallery
Its the wires in the door grommet. Willing to bet that a bunch of them are frayed and your window one was the first to completely get cut. I know when I opened up my driver door last summer, 6/7 wires frayed, the last one completely cut.
iovaykind is offline   Reply With Quote
Old 07-07-2011, 04:43 PM   #5 (permalink)
Mario Mobile
DM616's Avatar
Ooooh so it's just a loose connect between wires then?
But what is the grommet? No idea what that is lol.
Is that the piece that's between the door and body of the car, when you open and close? Somewhat flexible?
Old 07-07-2011, 08:17 PM   #6 (permalink)
iovaykind's Avatar
Yep, that's the grommet. It's extremely gay to work on. Hate it. But there's where all the wires are frayed. Because after so many years the grommet isn't as flexible anymore and rubs against all the wires and cuts them eventually.
You'll have to replace the wires, or solder them back together and tape it up nice and neat. I replaced all of them lol
Old 07-07-2011, 08:21 PM   #7 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
Yup. The wire bundle runs thru a corrugated rubber tube. I'd say check the driver's door; the bundle coming from the master switch. Because that door gets opened/closed the most, by far. I've had to go into that harness twice to repair broken wires. The tricky part is that the wire often isn't completely severed. Just the copper broken inside the insulation, which is intact. Makes it hard to figure out which wire is busted.
BMR is offline   Reply With Quote
Old 07-07-2011, 09:37 PM   #8 (permalink)
Mario Mobile
DM616's Avatar
Do you have to take off the door panel to get into the grommet or?
I'll be taking a look tomorrow.
Old 07-07-2011, 10:24 PM   #9 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
It's been a while, don't remember. I do remember the rubber tube fit in the hole in the door *very* tightly, so having the inner door panel off is pretty much required to get it squeezed back in. Gotta pull it in from the inside of the door.
Old 07-08-2011, 04:27 AM   #10 (permalink)
That's what the wiring diagram indicates ... the motor activating current goes through the RH front door operating switch to get to the window motor. If that switch has a fault of some sort, or is not connected, the window motor won't work .... either from the RH front door or the master switch on the LH front door.
However, the idea about the RH front door grommet also sounds plausible.
If the rear RH door window had a problem, the primary cause would more likely be the RH front door grommet location, but maybe that's what it is anyway.
The WD shows that at the door operating switch, the blue wire is always 12V, the red wire has 12V only for down operation, and the green wire has 12V only for up operation. The green with white stripe wire, and the red with blue stripe wire, both have to have continuity back to the power window master switch.
Old 07-08-2011, 10:15 AM   #11 (permalink)
Mario Mobile
DM616's Avatar
Oh nice okay I'll go double check the connection because I take apart anything lol.
Thanks for the info
