Is it that bad, or is it not that bad? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-08-2011, 10:05 AM   #1 (permalink)
View jnb0111's Photo Gallery
Good morning guys.
I got my car fixed this morning, and it's running good again. However, when I was at the dealer, the tech took me back to the shop and wanted to talk to me.
The oil light has been coming on in my car when i'm off the gas and the idle is down. When I give it gas, the light goes off. He said that it only needs 7 lbs of oil pressure to keep the light off, so if it's coming on, i've got basically no oil pressure, and that the bottom end is going out on the car.
The light has been doing that for a while, and I just figured it's something screwy with the light, so I ignored it. I had an old Tercel back in college that did the same thing, and I beat the snot out of that thing. The Camry isn't beaten on, but it's driven a lot.
Anyway, the tech said something about the bearings are going bad, and eventually, that will kill the motor. Of course, he coudln't give me ANY clue on how much time is left before this failure.
It's a '94 Camry, I've got almost 260,000 miles on it, and I JUST replaced the water pump and timing belt, which is not an inexpensive repair.
Anyone else ever have an issue like this that could give me an idea on what to do? Part of me says drive it til it dies, which may be today, or maybe much longer. Part of me says to just throw it on Craigslist as a running, driving "needs work" car, and still get probably $1500 out of it, and part of me says to trade it in on a new Camry. Downside there is that I have horrible credit, and this trade in is all I have for a down payment, plus maybe another grand.
jnb0111 is offline   Reply With Quote
Old 07-08-2011, 10:12 AM   #2 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426953
View EEngineer's Photo Gallery
top up the oil
more oil = more oil pressure
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is offline   Reply With Quote
Old 07-08-2011, 10:14 AM   #3 (permalink)
Originally Posted by EEngineer View Post
top up the oil
They did an oil change while it was getting the timing belt and water pump done, so it's already topped off...
Old 07-08-2011, 10:26 AM   #4 (permalink)
Born to Drive
EEngineer's Avatar
did you check with dipstick?
add more and see if it helps. oil is cheap, rebuilds are not
Rest in Peace
Old 07-08-2011, 10:40 AM   #5 (permalink)
Just checked. It's full. My whole thing is, if the motor is going on it, shouldn't it be knocking or doing something that screams "$$$$$"? It sounds good, that's the thing that confuses me. Sure, it doesn't sound like a 2011, but nothing sounds WRONG. I've worked at dealers before, and when an engine comes in that is oil starved, it's obvious as soon as you turn the key, you know?
Old 07-08-2011, 10:43 AM   #6 (permalink)
Born to Drive
EEngineer's Avatar
probably just the sensor being flaky.
as always, the dealership wants to f you over with some crazy bs
Rest in Peace
Old 07-08-2011, 10:48 AM   #7 (permalink)
That's always my first thought, too. (The dealer trying to f me over, not the sensor being flaky, although that crossed my mind, too... They didn't try to sell me anything, though. Just told me and said that with the age and the mileage, he would just drive it. I guess I could add another 1/2 quart or so, and maybe OVERfill it, but I don't want to break any seals or gaskets, either.
Old 07-08-2011, 10:50 AM   #8 (permalink)
I cheated with 7075 Al
N/A Camry Sleeper's Avatar
Gameroom cash: $161600
View N/A Camry Sleeper's Photo Gallery
A few ideas here...
Your oil pump could be internally leaking - Doesn't happen that often but it COULD...
The oil pressure sender could be caked up which would result in an erroneous reading - again, doesn't happen that often but the potential is there.
ALso, your pickup screen may have debris in it preventing some of the oil from getting into the pump - thus lowering the pressure.
What I would do is:
1. Remove oil pan and inspect pickup screen - clean if needed
2. While the oil pan is off; remove balancer shafts and throw them away. Plug the oil feed hole (This will raise your oil pressure at ALL RPMs and will lube your engine a lot better) Check the forums on the procedure. The dealer won't do this for you BTW. BE SURE YOU PLUG THE OIL FEED HOLE OR YOU WILL HAVE LOWER RESULTANT OIL PRESSURE!
3. Check all the gaskets for any leakage. This can also reduce oil pressure
4. Remove and inspect the oil pressure sending unit - look for signs of blockage
5. Theoretically you could replace the main and rod bearings while the pan is off but if your engine sounds good then there's really no need. All depends on how deep you want to dive with it!
Good luck!
1996 Toyota Camry 5SFE 5-spd 329.9K - UNDER REPAIR
1997 Honda Civic 1.6 5-spd - 183K and 27 MPG average - Dependable DD and *small* family car
1991 Acura Integra 1.8 5-spd - 241K and 28MPG average - I'm game for a simple LS Vtec swap now...
N/A Camry Sleeper is offline   Reply With Quote
Old 07-08-2011, 11:04 AM   #9 (permalink)
nitronate33's Avatar
View nitronate33's Photo Gallery
could be your oil pump, could be your sender that feeds the gauge inside the car. to find the truth, you need to check your oil pressure properly with a gauge to find out if the sensor is the problem or the actual oil pump.
a shop should be able to check the oil pressure properly to find out if it is low. this is the first thing they should do to diagnose the problem. if it is just the sender (in many cases it is), it's a cheap fix.
2005 Toyota Solara SE 2.4L
2004 Subaru Impreza WRX 2.0L
2011 Ford Mustang Shelby GT500 5.4L
nitronate33 is offline   Reply With Quote
Old 07-08-2011, 11:19 AM   #10 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
^+1...first see if there is something to worry about....oil sender to right up on top front of the engine near the coolant outlet. If you want to check it yourself, Harbor Freight sells a decent oil pressure gauge, but you should be able to just rent / borrow one from a parts store. Oh, and the sender requires a special socket to remove / replace -- strangely enough they're called "oil pressure sender sockets" And don't overtorque the sender when replacing -- the threading on that thing is weird, and I've actually heard of people cracking the head overtorqueing it.
BTW, I like to call the oil pressure light the "you're screwed" light, because by the time oil pressure is low enough to trigger the light...
Old 07-08-2011, 11:26 AM   #11 (permalink)
i'll check on borrowing a pressure tester from autozone or advance today. Will post back results.
Old 07-08-2011, 11:42 AM   #12 (permalink)
RIBMIESTER
JimBowNut's Avatar
Gameroom cash: $134901
View JimBowNut's Photo Gallery
Are those balancer shafts just a waste of energy ? I was told that they take out the fine vibrations from the motor ? (Toyota Master Tech). Is it just a waste for what they do ?
JimBowNut is offline   Reply With Quote
Old 07-08-2011, 12:51 PM   #13 (permalink)
View agni's Photo Gallery
From what I understand, the balance shafts are there solely to reduce the vibration felt by the passengers, and do not affect the internal balance of the engine components.
agni is offline   Reply With Quote
Old 07-08-2011, 01:48 PM   #14 (permalink)
View curry.style's Photo Gallery
Balance shafts balance the motor...plain and simple. Inline four cylinder engines by design are horribly balanced and require some sort of additional balancing. I've seen people remove the balance shafts for horsepower gains on various applications with few ill effects as far as wear and tear. However, the car will have vibrations at idle in the passenger compartment without it.
As far as your oil problem, check for signs of leakage on the bottom backside of the timing cover. It is fairly common in my experience for the oil pump to block gaskets to leak. Out of 4 5SFE motors that I've seen they all needed it.
Hope this helps, good luck.
331,000 miles and the wife's 1995 Camry LE finally bit the dust...but we can rebuild it, we have the technology...
1993 Camry LE wagon, 4 cyl, 5 spd swapped...more to come...
curry.style is offline   Reply With Quote
Old 07-08-2011, 02:19 PM   #15 (permalink)
ok, I checked. The back side of the valve cover gasket is kinda leaky. I didn't see anything anywhere else, at least from the topside of the engine. Since I just got the timing belt replaced, is it possible (probable)) that they would have cleaned any oil from the timing belt cover, or is that just not very likely?
i'm not very mechanical right now, although I AM going to school to be a mechanic, so this time next year I'd be confident in my abilities, but right now, dropping the oil pan kinda worries me. Mainly because this is my only car. If I had to, I could drive my gf's Cobalt, but... I'd rather not.
The autozone here doesnt' have a tool to check the oil pressure, so it's at an independent shop right now. The guy there said he'd check it over and let me know.
