the same exact ones. the ecu is programmed to go into a fail safe mode which cuts off a solenoid disabling shift to second..could be a different problem if you cant get into reverse, search online for a pdf file of the shift solenoids for that transmission. theres a elimination chart of what your trans can and cant shift to when a solenoid goes out.
i sent my car to the shop and they were honest to say that the transmission was not the problem, not even the solenoids. prior to that i even tried dropping the pan to check any loose connections or shavings but was still clean and perfect fluid. i changed the ecu the next day and she works like a champ. it happened around the same mileage as you. unluckily i blew that ecu after i started my car while it was on about 3 months later so im on my 3rd ecu
google my friend
