92 camry, with no spark? help please :(
Hi all, I have a 1992 Toyota Camry V4 with a 2.2L engine.
About a week ago or so i went out to leave and the car wouldnt start, would turn over but had no spark. Checked all the fuses, under the hood and also inside the car, all were good. Changed the dist. cap and rotor.Still no spark. Changed the Ignition coil and tried to start it, started right up with no problem. After about a week or so i pulled it ino the driveway to put some liquid steel on the exhaust because there was a little hole causing a bit of noise. Once i pulled it in, and fixed the whole, i tried to leave and the car wouldnt start. Same thing will turn over and everything, gets gas but no spark again. The ignition coil that I bought was an aftermarket one, not one from the toyota dealership. Also today i went to the junkyard and grabbed 2 distributers to try and both had no affect, car still wont start, no spark.
Any Ideas for me?
