radio wire harness light panel wire - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-10-2011, 05:19 PM   #1 (permalink)
View james42519's Photo Gallery
i am trying to put another radio in my 96 camry but i don't see a wire for the light panel. where do i hook the wire too? also would it effect stuff with eh radio being 4 ohm and the stock speakers being 6 ohm? this is the radio i am putting in BTW. rms is 21 watts it says.
http://www.vr-3.com/product.php?p=VRCD400SDU
sorry if this has been asked already.
james42519 is offline   Reply With Quote
Old 07-11-2011, 04:52 AM   #2 (permalink)
ok i figured it out. apparently it is the j wire that install dr says do not use. i looked at the wires on the wire harness i got and seen they are labeled what each one is and the orange one in the j spot is the ones for that. so does that mean i can just use that and it will work or is it not hooked up on the car at all even though there is the wire?
Old 07-11-2011, 11:32 AM   #3 (permalink)
View White95Cam's Photo Gallery
Originally Posted by james42519 View Post
ok i figured it out. aparently it is the j wire that install dr says do not use. i looked at the wires on the wire harnes i got and seen then are labled what each one is and the orange one in the j spot is the ones for that. so does that mean i can just use that and it will work or is it not hooked up on the car at all even though there is the wire?
Yes it is the orange wire and it is hooked up.
W95c
White95Cam is offline   Reply With Quote
Old 07-11-2011, 03:44 PM   #4 (permalink)
W95c
ok thanks.
