Head Bolt Problem 93 camry. pic included - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-11-2011, 05:07 PM   #1 (permalink)
View arim's Photo Gallery
victor reinz Head Bolt Problem 93 camry.
Installed RH head gasket last night. I noticed that at least one of the bolts was grabbing in one spot as I cranked in down. I was in a hurry and just ignored it. Thought about it more latter on. Decided to check the other set. Discovered that at least two bolts were bent one worse than the other. These were brand new Victor Reinz head bolts. Painted one bolt, you can see where the paint rubbed off. The other pic shows a 180 turn of the bolt in block. With the square held in the same position the bolt swayed back around 3 mm. Are these bolts no good? and presuming one is already installed, do i remove and replace the whole RH set. I am currently waiting for a response from Victor Reinz via supplier ( it's slow coming). That's at least 3 bent head bolts out of 16. Not good. Thanks for any replies.
arim is offline   Reply With Quote
