Compressor Jammed, Need Cheap Fix - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-11-2011, 08:28 PM   #1 (permalink)
View CrimsonEclipse's Photo Gallery
I have a 1993 Camry and the compressor has seized up.
I don't need the A/C and it didn't work anyway but I need the cheapest
and easiest way of returning to driving.
I've seen bypass pulleys on other vehicles to replace a not needed compressor.
Or can I just remove the compressor and use a shorter belt?
Money is a MAJOR factor.
(also, my first post here... HELLO!!!!)
CE
CrimsonEclipse is offline   Reply With Quote
Old 07-11-2011, 09:05 PM   #2 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
You can remove the compressor and use a shorter belt. Or leave the compressor on and use a shorter belt, it shouldn't get in the way anyway. Just take a piece of string, start at the alternator and go around all the pulleys like normal, but skip the compressor. Then measure how long that is, go to a parts store and say "I need a XX ribbed belt that is YY inches long". In the part numbers of belts, the last 2 or 3 numbers in length in inches, and the first is the number of ribs. Then some letter are added in for different brands and varieties.
For instance, a belt that is K060445 would be 44.5 inches and 6 ribs, whereas K04022 is a 22 inch belt with 4 ribs.
Chris Crash is offline   Reply With Quote
The Following User Says Thank You to Chris Crash For This Useful Post:
CrimsonEclipse (07-13-2011)
Old 07-13-2011, 12:02 AM   #3 (permalink)
Shorter belt, WONDERFULL!
I'll likely remove the compressor. Many thanks.
CE
