'96 Camry Antenna Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-12-2011, 11:44 AM   #1 (permalink)
View LE Camry's Photo Gallery
Hi all, new to the forums here. Thought you guys might be the best to help answer my question accurately. I have a 1996 Camry LE, and the antenna has stopped going up and down, and is generally in bad repair. It's the metal telescoping type, and it seems to be broken beyond repair. My question is: we got it quoted for >$100 to fix, and to me that just seems ridiculous. I looked online and found that the entire stainless steel antenna mast system can be bought for ~$75. However, I also found a cheap plastic ~$5 antenna that says is compatible with any 1996 Camry subtype. Seeing as how funds are low, I'd be doing the installation myself, and I don't care if it's plastic or not; I just want my radio to work. Anyone know if the plastic model is compatible with my car, even if I have a stainless steel type already? And would I be able to install it with no (repeat: no) car saavy?
Also, where would be the best, most honest online parts shop to consider buying from? There're a lot of different online auto-parts stores, but I have no idea who is more honest and who is the best to go through, esp. with Toyota parts. Thanks
LE Camry is offline   Reply With Quote
Old 07-12-2011, 12:02 PM   #2 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
i dont know specifically of the plastic one you are referring to, but i bought my replacement mast from pep-boys and it has worked like a charm. i believe it was about $25ish.
Old 07-12-2011, 12:07 PM   #3 (permalink)
30YRTOYOTAPARTSEXPERINCE
TOYOPARTSMAN's Avatar
Gameroom cash: $324600
iTrader Score: 12 reviews
View TOYOPARTSMAN's Photo Gallery
I personally haven't found any aftermarkets that work well. But that is me personally. As far as your antenna goes, if the motor is still working chances are the cord inside is broken, you'll have to disassemble the antena, get all the old cord out and reinstall with a new one. A new OEM one is $73.78 MSRP.
As far as Honest Parts places goes, I like to think of myself as one. Ask around in here about me. I give TN members in here 30% off MSRP so if you decide to go OEM, I am here for you.
I wish you the best of luck with your situation and if I can be of any help, don't hesitate to contact me.
Gary Smith-Parts Manager
garys@toyotaofnewnan.com
www.ToyotaofNewnan.com
678-854-9601
TOYOPARTSMAN is offline   Reply With Quote
Old 07-12-2011, 12:29 PM   #4 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
If you just want radio, then just extend the antenna all the way up (or just part way up) and pull the plug from the motor.
I don't think I'd trust a $5 plastic antenna, but the $25 generics work OK for a while.
In addition to the options of using an OEM replacement or a generic from the local parts store, you could look into the S2000 Antenna Conversion -- it's a mite spendy up front, unless you're lucky at the junkyard, but you don't have to mess with the power antenna any more. After my second (OEM both times) antenna bit the dust, I got tired of replacing it and did the conversion. Never regretted it.
Old 07-12-2011, 06:30 PM   #5 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
You can get a new antenna mast on Ebay for about $10-12, I bought one for $10 a few months ago and the shipping was free. The thing works fine, no complaints.
Just do a search for Camry Antenna Mast.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
Old 07-12-2011, 08:14 PM   #6 (permalink)
View jnb0111's Photo Gallery
Mine has a non power mast, a la 1997 Camry CE. It works fine, especially since my radio doesn't work, anyway. Stupid Pep Boys pos no brand thing.
jnb0111 is offline   Reply With Quote
Old 07-12-2011, 09:06 PM   #7 (permalink)
Well what I'm not completely sure about is what exactly I'd need to make everything work. When I start my car (and turn it off), it makes the whirring noise of the motor, yet it doesn't retract my antenna. This leads me to believe I might just need a new mast. However, my antenna mast is stuck in the always deployed position. My question is whether or not the reception on the radio will stop being spotty if I buy just a new mast, considering my antenna is already up all the time. And I'm not sure I'd need the whole thing replaced, because the motor still seems to be attempting its job.
Old 07-12-2011, 09:27 PM   #8 (permalink)
71Corolla's Avatar
First thing you should do is unplug the antenna power connector, or eventually the motor will burn out. Is the antenna up all the way? These cars have a really long antenna which gives great radio reception.
Old 07-12-2011, 09:29 PM   #9 (permalink)
Yeah it's all the way up as I mentioned before. I wouldn't have the slightest clue on how to disconnect the antenna motor..... But the question still stands: is it worth replacing if my antenna is already fully deployed? Why am I not getting good radio reception whatsoever?
