To do this you will need:
- Gen4 or Gen4.5 steering wheel
- Gen4 airbag (1997-1999)
I believe the steering wheel from the CE trim is a lower grade wheel and is essentially the same as what you have now. You can't use an airbag from a Gen4.5 (2000-2001) because the connector is different. On my 1993 Camry, the steering wheel is from my ES300 (same wheel as a Gen4.5 XLE Camry), the airbag is from a 1997 Camry LE. Either way when you get the airbag, confirm it has the same connector as your old one.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
