So I picked up a 19MM deep well socket (as mentioned in a previous post) to remove my ECT sensor but that was too small. Went back for a 20MM but they only had a 21MM which fit but had a little wiggle room. Loosened the sensor as easy as I could and ...
hill8570 was dead on with his assumption about plastic on a sensor from 1995.
Now, I hand tightened in a new sensor then tried to tighten further with pliers which didn't really cause the sensor to tighten further. When I reattached the connecter it was now aligning one half revolution away from the original OEM sensor position. The arrow points to where the press-clip originally faced.
I let the car run for about 15 minutes and notice no leakage at the sensor but will keep an eye on it this week.
Question ... what is the correct size socket for the ECT and is it possible that the aftermarket version and OEM version would not line up to the same location when fully tightened?
