AC evaporator leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2011, 07:52 PM   #1 (permalink)
Jim
View Jim Waechter's Photo Gallery
AC evaporator leak
I have a leak under the dash that appears to be a clogged AC evaporator drain. What is the best way to clear this drain? Can it be done from under the car or do I need to get behind the dash? Where should I look for this drain? Thanks!
Jim Waechter is offline   Reply With Quote
Old 07-13-2011, 08:17 PM   #2 (permalink)
I wrench, therefore I am!
Gameroom cash: $214200
View TedL's Photo Gallery
Peel back the carpet from the front pass. side near the tunnel. You'll see the tube, and be able to disconnect from evap box.
TedL is offline   Reply With Quote
Old 07-14-2011, 06:06 PM   #3 (permalink)
Jim
You're a genius TedL. It was right where you said it would be, and plugged solid with debris. Problem solved! Thanks again.
Jim
