Live data & I/M Readiness - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2011, 09:55 PM   #1 (permalink)
View avcamry's Photo Gallery
its for a 2000 camry CE 5sfe
Greetings all
I am a new Toyota owner but not new to these wonderful forums
I am hoping someone may be able to interpret these read outs and give me some direction,
I have not yet run 2 tanks of gas but feel something is not right
the first tank gave me more milage than this current tank
I did get a P0420 code cleaned the blazes out of TB IAC, EGR, and intake
this seemd to make the error go away for a while
my CEL came on I did a scan
now I get a P0420 & P0172
I ran a scan and the following readings came up
I would be so greatful for any and all feedback
I do all work myself
my sacanner does not have a memory so I had to write down the readouts
I suspect i got some letters incorrect v instead of u perhaps etc. so if you think a letter is wrong it may very well be so but the numbers/ readings are right
I guess that load pct% at 29 is high, so what would the fix be?
anyway I await any and all feedback
Thanks in advance
Liam
I/M Readiness
since DTC cleared
MIL status off
misfire monitor ok
fuel sys mon ok
comp compnent ok
catalyst mon inc
htd catelyst NA
Evap system mon Inc
sec air system NA
Ac refrigeration mon NA
Oxy sens mon ok
oxy sens htr ok
egr system ok
CODES 0
Monitors NA 3
Monitors OK 6
Monitors Inc 2
LIVE DATA
DTC_CNI 0
fuel sys1 cl
fuel sys 2 N/A
load_PCT% 29
ETC F 214
SHRTF + 1% 4.7-8.6
long fTI% 25
map nHG 8.6
RPM 701
VSS mph 0
spark adv 4/5/6
IATF 118
TP% 9.8
02B152(V) .015 - .680
OBDSUP OBD II
EQ-RATB151 .996 - 1.008
02B151 (u) 3.221 - 3.304
avcamry is offline   Reply With Quote
Old 07-14-2011, 01:05 AM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
having the Long Term fuel trim at +25% can't be good, sound like a serious vacuum leak maybe?
P0420 is the catalyst monitor error if I remember correctly. take it for a drive on highway at 55mph for 15 minutes (try doing this at a steady speed) then take nearest city exit and do another 15 minutes of local driving at no more than 2,500rpm at max 35mph, it should get passed if catalyst converter is OK (catalyst monitor complete/ok).
if it doesn't want to get passed, maybe start with replacing the downstream oxygen sensor for it (post cat o2 sensor).
Old 07-14-2011, 03:20 AM   #3 (permalink)
Pvt-Public's Avatar
Gameroom cash: $274350
View Pvt-Public's Photo Gallery
On my 1999 5sfe I replaced both 02 sensors (front is an A/F sensor on Cali models) and no P0420for almost a year now. And if a sensor is not reading right that may also be your P0172 code too.
Pvt-Public is offline   Reply With Quote
The Following User Says Thank You to Pvt-Public For This Useful Post:
avcamry (07-14-2011)
Old 07-14-2011, 01:48 PM   #4 (permalink)
4th Generation txs
I forgot that they are indeed A/F sensors, so is this the sensor that tells the ECU to modify the fuel mixture? it seems to be a new sensor, but I read a post that you don't mess around with these only use oem, wouldn't bet the farm that oem was used
thanks again
