Have air, fuel but no spark...sigh HELP! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-14-2011, 09:39 PM   #1 (permalink)
View latinflex01's Photo Gallery
Hey all! New here.
I have a 1992 Toyota Camry Le 4 cylinder (5fse engine) and it died on me. Engine turns but doesn't ignite. I've changed the fuel filter and with that tested the fuel pump and i got gas coming into the chambers but no spark. All spark plugs aren't charging. So i changed the ignition coil and distributor cap and still nothing. Tested current is definitely reaching the ignition coil but still nothing passes through to the spark plug wires.
I'm reasoning the only thing left is the ignitor? (ignition module--200 bucks at autozone). I found a used one on a junkyard and getting it in the mail for just 20 bucks so you can't beat that...so playing the waiting game. Just hoping that really will resolve the issues. We all depend on our vehicles don't we?
Well, i wanted to see what the thoughts on the forums were about this problem? Any ideas? or is it for sure the ignitor?
Thanks so much for your time.
-pepe
latinflex01 is offline   Reply With Quote
Old 07-14-2011, 10:14 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Have you checked that the distributor rotor is spinning when you crank the engine? A broken timing belt is a common way for an engine to stop getting spark.
Old 07-14-2011, 11:36 PM   #3 (permalink)
I'd do that by just popping off the distributor cap and seeing if the rotor spins? Man that opens up a big can of worms...sigh.
Old 07-14-2011, 11:38 PM   #4 (permalink)
If the timing belt broke usually it's super bad news for the engine but i read somewhere on here that it's not the case on this car?
Old 07-15-2011, 12:38 AM   #5 (permalink)
Non interference engine so phew! I understand that now. Okay, tomorrow i'll definitely check that out and see and update.
thank you
Old 07-16-2011, 02:36 PM   #6 (permalink)
okay, rotor spins but not fast. What does that say? possibly the teeth off the timing belt are gone and it didn't break? still needs to be done obviously but how does that affect timing?
Old 07-17-2011, 10:27 AM   #7 (permalink)
Gameroom cash: $303755
"Tested current is definitely reaching the ignition coil but still nothing passes through to the spark plug wires."
Since you changed out just the distributor cap, I would inspect that rotor carefully. Remove it from the distributor and check it all over, including the underside, for evidence of cracks. On a much older car, I once had a rotor crack underneath where it sits on the shaft of the distributor. It would short itself to the distributor shaft. Took me quite a while to figure that one out.
Mike
Old 07-17-2011, 11:42 AM   #8 (permalink)
Would you guys recommend replacing the distributor itself eventhough i already rebuilt it basically (except the rotor which i'm about to now---only a 4 dollar part...what do i care right?).
I just looked at it...it's not cracked but definitely has a scorch mark down in the wedge towards the bottom (around the plastic...not metal?)
Old 07-17-2011, 12:42 PM   #9 (permalink)
tacosteelersman's Avatar
Gameroom cash: $170177
View tacosteelersman's Photo Gallery
My Tacoma did the same thing. You have a condensor (thats right an old fashioned lawnmower type condensor) in the distributor. Its a cheap part and odds are it will do the trick.Good luck
95.5 Tacoma 2.7 300,000
91 Corolla 1.6 180,000
96 Avalon 3.0 190,000
95 Ford Aspire 1.3 125,000
tacosteelersman is offline   Reply With Quote
Old 07-17-2011, 01:35 PM   #10 (permalink)
Man, i just changed the rotor and it fired right up. Thank you so much. I basically gave my car a tune up it badly needed but the final piece...the rotor did the trick.
Thank you so much everyone for your input and experience. Gained my independence back
Definitely think i need to do the timing belt anyways so i'll get on that one next weekend.
Thanks again all for your time, thoughts and experience!
