96 camry airbag light won't reset - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2011, 02:51 PM   #1 (permalink)
View erikm12's Photo Gallery
Ok, my light stays on.
I tried the TC/AB method and that clears it as long as I keep the ground on the TC connected at the end. As soon as I pull it off the light comes back on.
Before the light is cleared (temporarly) it'll blink twice then pause then twice more before the light goes out. As soon as I unconnect the ground from the TC the light comes back on solid.
I have taken both battery cables off, checked the fuse and that is about it.
I have not had the steering wheel off. I might have had the seat out running stereo equip. The light was covered up with a pic and I got a rejection sticker today because of it. Only reason i don't know how long this has been going on. Any ideas will be appreciated....Thanks.
erikm12 is offline   Reply With Quote
Old 08-26-2011, 07:39 PM   #2 (permalink)
bump still have the problem
Old 08-26-2011, 10:30 PM   #3 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
When the light is cleared correctly, it will blink really fast. If you have not got to that point, you have to keep trying, it can be very frustrating to get the correct sequence.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
Old 08-26-2011, 10:39 PM   #4 (permalink)
camrtm3's Avatar
Gameroom cash: $102305
View camrtm3's Photo Gallery
Take it to a toyota dealer, if there is no fault all they will need to do is reset it. search for my old thread for this. its about 2 years old but i had the same issue.
2009 EX-L V6 6Spd MT w/Nav (stock for now)
1996 XLE V6 Camry, KSport GT Pro 9/7, TRD RSB, E153 5spd conversion, Gen 3 front end conversion, OBX Headers, Megan Cat Back, TRD M62 Supercharger
Supercharger whine > ex girlfriends whine
http://www.cardomain.com/ride/3329124
camrtm3 is offline   Reply With Quote
Old 08-28-2011, 06:29 PM   #5 (permalink)
I can clear the light but when it restarts it comes back on. So I do have something amiss. I would like to know how to get a code so i can look into it. Like if a front sensor is bad.
I have a scanner and when plugged in doesn't give me a code. Is there another way to get codes? Thanks
