Alignment Sheet, front camber - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2011, 10:47 PM   #1 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
Got an alignment today at a local shop. The technician is a former master tech at park place Lexus so he knows these cars, nice guy.
A couple things are off, since the car is lowered the camber was still off in the left front tire. He explained and illustrated what I need to do to. First, since there is still a slight pull to the right, he told me to swap the front tires in case there is radial pull in them, then loosen the strut to knuckle bolts on the driver's side front and pull the strut out in order to fix the camber, then bring it back to the shop tomorrow to re-align it.
Also, what is the "SAI" adjustment?
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 07-15-2011, 11:20 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
SAI is steering axis inclination. It's the result of suspension geometry and the vertical line through the center of the tire on FWD MacPherson designs. It's not directly adjustable itself. But if you pull the bottom of the strut out I think it will increase a bit?? Or maybe not enough to be measurable. My guess is the higher than spec value SAI is because you lowered the suspension but not really sure.
Are you on stock bolts? I'd be interested to know how much adjustment is possible. There's supposed to be no adjustment with stock bolts, but maybe there is enough wiggle room.
Old 07-15-2011, 11:42 PM   #3 (permalink)
Avy
Seems like SAI is affected by camber?, but isn't something to really worry about.
Yes, the bolts are stock. He said a little movement can be done, looking at the front left tire from a distance and you could see the camber was too positive. I know the strut can move inward and outward, so I would move it inward a little and push the steering knuckle inward as well. That seems like it would work, I will see tomorrow.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 07-16-2011, 12:00 AM   #4 (permalink)
AFAIK, on MacPherson designs it's measured differently than short-long-arm (Honda) type suspension systems. But what little I know at least on SLA it's affected by camber.
Your camber right now should be too negative. Just like cars with new springs sagging, those cambers go negative too. (That's why it's a good idea to check alignment after the first 15K miles or so on new springs).
So the top of your tires are tilting inward (not outward)? That's negative. You should pull the strut out and tilting the top of the steering knuckle out (making the top of the tire come out, away form the engine bay) to get more positive camber, which I think is what you need, right?
Old 07-16-2011, 12:29 AM   #5 (permalink)
Avy
Your camber right now should be too negative. Just like cars with new springs sagging, those cambers go negative too. (That's why it's good to check alignment after the first 15K miles or so on new springs). So the top of your tires are tilting inward (not outward)? That's negative.
So you should pull the strut out and tilting the top of the steering knuckle out (making the top of the tire come out, away form the engine bay) to get more positive camber, which I think is what you need, right?
From what I saw, the top of the tire was more outward than the bottom.
The tire looks more like the positive camber on the chart which has me completely confused right now. I need to look at it from a distance again.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 07-16-2011, 01:20 AM   #6 (permalink)
Do double check, because your alignment report shows -1.2 to -1.4 negative camber, which means the tops of the tires should tilt toward the engine bay.
Old 07-16-2011, 02:15 PM   #7 (permalink)
Pvt-Public's Avatar
Gameroom cash: $274350
View Pvt-Public's Photo Gallery
So you got the alignment checked, but since it pulled you knew it was probably off to start with. Why didn't you just let the shop do the adjustments while they had it on the alignment rack? And why are you attempting to do the adjustments only to bring it back to the shop and have them align it? You do know you can not accurately eye ball an alignment right?
Pvt-Public is offline   Reply With Quote
Old 07-16-2011, 05:56 PM   #8 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
why not buy a camber/caster bolt kit for lowered cars, replace those bolts (giving wider range of adjustment) and let the shop re-align it properly?
I wouldn't touch it myself. as above, it's impossible to accurately eyeball wheel adjustments...
Old 07-16-2011, 06:37 PM   #9 (permalink)
View mr1114's Photo Gallery
Camber bolt, cheap and very easy fix. Install in place of one stock bolt, and will give plenty of room for adjustment.
And by looking at the camber and caster, the pull is probably radial from the tires.
2006 Corolla S - sold
2003 Solara SLE - sold
2000 Corolla LE - sold
mr1114 is offline   Reply With Quote
Old 07-16-2011, 07:27 PM   #10 (permalink)
Avy
I was able to pull the driver side front strut out about a 1/8-1/4" so it should be in spec now, probably around -1.0. I will take it back on Monday to get the alignment rechecked, still pulling to the right after I swapped the front tires, a little more now. So I think the alignment is still off and a little radial pull in the tires, will see.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 07-16-2011, 08:19 PM   #11 (permalink)
Pvt-Public's Avatar
I still say your best bet is to let the shop do the alignment and quit guessing at it. Or do you really think you can see the difference between 1 and 1.5 degrees? And besides you will waste more time playing with it and getting it rechecked many times over. Just the time being wasted going back and forth to and from the shop and the time to check it, (not even counting the labor involved in guessing at adjustments) is worth more than an alignment charge.
Old 07-16-2011, 08:26 PM   #12 (permalink)
Right, what was the reason the shop didn't loosen the two bolts and pull the strut out?
Old 07-16-2011, 09:27 PM   #13 (permalink)
Avy
When I went to pick up the car yesterday, it was almost closing time and my friends who gave me a ride had to go somewhere...so he told me to do those adjustments, and bring it back to him if anything is wrong and he will fix it, so that's what I'm going to do on Monday.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 07-17-2011, 01:08 PM   #14 (permalink)
That seems like a lot of play. Those are probably undersized mounting bolts then.
Old 07-19-2011, 04:42 PM   #15 (permalink)
Avy
Got the alignment fixed, me pulling the strut out brought the camber -1.2 on both sides. Also the mechanic fixed the pull, its basically gone. He said after I get new tires and realign it should be good. He told me to get a tire with at least 700 treadwear, so I found Yokohama AVID TRZ tires with 700 treadwear, A traction and B temperature. I will need these by the end of the year. He's a very nice guy, he let me watch him do an alignment and explained how it works.
99 Avalon XLS-149k
99 Lexus LS400-88k
